Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: hard to start/bad MPG
    1987 ACCORD LX
    ONTARIO CANADA
    if ur g2 carb is f ing u so much go to the junck yard and get a old civic carb witha manual choak thse carbs u can adjust anyway u want the only thing is u might have to drill the fule jets out a bit like find a tiny bit that fits the jet and go one size biger it will run ur 2 L just right got milege and half deasent speed and only 3 vac lines on the civic carb and the carb should fit ur intake cause the g2 and alot of civics have the same carb mounting just hit the junk yard up and look around also hundai pony carb might work my friend is runnig his g3 with a pony carb no vac lines at all
    but he had to make a transfer plate hundi suck but the pony was a cool winter beater it just went
    1987 ACCORD LX
    ONTARIO CANADA
    also the guy who told u ur running lean might not be right u get black shit cause ur fule isent burning wich in most cases means u got to much fule to burn also cold be a bad plug so one cilinder isent combusting could be ur conpretion is shit like berly any compretion at this point it wont combust fule like it should and it could be ur valve seals ar done and poring oil into the cilinder when the valve opens or it could be all of the above pull the plugs if any of them are oily and black that means that cylinder isent fireing right if thier farly old and things are ok ur plugs should be a a dry light brown a littel black shit is ok
    Jul 2004
    85 Accord ES2
    Neosho, MO
    the poluga are only a month or so old, but i dont know about the wires and coil. the distributor and rotor are only a few months old. but i think ill pull the plugs and check em out.
  1. Hard Start (did everything I know)
    By Timaculent in forum Classic Honda Community Chat
    Last Post: 10-09-2008, 04:20 PM
  2. Hard to start cold
    By Leanback in forum EFI Tech
    Last Post: 04-09-2006, 03:40 PM
  3. Hard to start when hot.
    By carotman in forum 3geez Accords
    Last Post: 06-08-2005, 10:45 AM
  4. hard to start.....
    By pipashlee in forum 3geez Accords
    Last Post: 07-02-2003, 09:12 AM
  5. Car is hard to start WTF!!!!!!!
    By BigCook in forum 3geez Accords
    Last Post: 06-16-2003, 07:57 AM
