hey guys, I have an 82 Honda Accord with a Keihin carb. the carb was idling weak and almost stalling , so a mechanic turned the idle screw up to 1000rpm to keep it a bit more stable; it was a bit more stable. Then i took off the carb to check the gaskets. When i put it back on , the car was idling very fast 1750 in neutral, 1100 in drive. the choke cable is completely loose, the throttle stop screw is out. I checked the hoses, and I can't find an incorrect correction or a vacuum leak. Any and all ideas are appreciated. I've been working on this for weeks now.
