Ok i am Thinking of putting a B20A in.I would like to hear from you guys Who has done it and if you have pic's post them PLEASE. Thank you
I did it... and documented alot of stuff on here.
I need these parts!
do you have any pic's of the motor mounts and what motor mounts do you need to change to make it fit?
I've done it but i'm not a wiz wit puting pics and things on here.
I can mail them to u tho, u going F.I. or carb?
any help? pm me
carotman What Honda are the B20A Come from and years of them?
wow carot that is B-E-A-Utiful. nice work man. Looks stock at that. OHHHHHHh
Well i found a B20A for $550. it a good deal but i does not have the mounts for the power steering or the alternator or ac so does any one know where i can get them at?
good luck...when ya find b20 mounts lemme know.. i need some too
It's all the the FAQ guys... do a little reading and come back.
The B20A mounts are the same as the A20A... you only need to use the rear tranny L bracket from the B20A but that's all..
I need these parts!
carotman Can you take some pic's of your motor mounts and post them that would help me alot
tranny L bracket....any pix of that, part number to a corresponding usdm part? is that welded to the frame or bolted?Originally Posted by carotman
Originally Posted by snoopyloopy
hmm....so what exactly am i looking at?
^^^^^ I think we would all like to know :)
The first three pix's are of the P/S brackets and the last two pix are of the B20a tranny L bracketOriginally Posted by snoopyloopy
so it's a bolt-on affair?
Its all bolt in if you get the right stuff. Everything has been posted in Carotmans and YK86's posts. There is a lot of info on here and iv posted lots of things here as well.
It is very hard to find a complete B20A there are many floating around but its hard to get one with everything you need so if you want to do this swap get ready to do some research and you will need some fabrication depending how complete of a swap you find. For starters most only have the exhaust manifold w/o a downpipe and its different so you need the downpipe unless you modify a prelude header which are hard to come by these days (aftermarket). But there are many options as for what you can use for parts and you will still need to get your hands on JDM parts which is a pain but makes it interesting cause what you have is something that you wont see at every car show. Im still trying to finish my project but its on hold until i get my debt taken care of but im hoping to work on the motor by spring time again.
