Okay Guys,
I was getting alot of front end shaking when I started to brake. Back in Nov 03 I did alot of catch up on the maintenance Clutch, rear main seal, upper & lower ball joints brakes all the way around, power steering pump, dizzy, oil pan gasket, oil filter base seal, crank seal, cam seal, oil pump seal.
Basically everything in one shot. After the brake job I had to return the rear drums and go to the next grade higher the standard autozone were out of round and caused the brake pedal to pulse.
After the replacement the pulse went away.
Then the front end shaking while braking started to appear I originally thought the calipers needed rebuilding after regreasing the caliper pins didn't work. But then I remembered one thing a Honda master mechanic had told me
"Never use an impact when tightening lugs on a Honda"
Well I've been doing this for along time and never really had a problem until now. Just replaced the rotors and the front end shaking is gone.![]()
Good thing they were under warranty.
