1 can i get a black box that dosen't use EGR ?
yes you can, they were available on euro models, but they are hard to find.
have you cleaned the EGR valve?
have you reset the ECU after you install new EGR or reinstalled the cleaned one?
i've gone through 2 motors bolth times code 12
I have a 1986 Accord Lxi with fuel injection. I believe I have located the EGR valve, however was is that silver rectangular thing strapped down over the valve? I keep getting code 12 also and was considering cleaning the valve.
if you take off the egr you should clean both mating surfaces reallygood and get another gasket for it. carefully see if the ?diafram? (stupid inglish) moves easilywhen you push the little button. Check your vacuum lines. i tried taking off the egr in the black box, butcouldn't figure outif it was bad or good. so i just ignored that stupid code.
- Col Jack O'Neal - Stargate sg-1."If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
I bet you should try changing the sensor on top of the egr valve... if that doesnt help than make sure the valve isnt seized (it can happen)
there is a sensor???? i just htought it was wires and that there was nothing to replace on the egr. hmmm that's interesting to know.
good info to know.. hmmOriginally Posted by Immeraufdemhund
'honda makes people happy'
