Results 1 to 25 of 43
Thread: apexi s-afc install and settings q?
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    Does anyone have an wiring diagram and settings for this? i got a used one for 100 bucks and i have a faint idea how to wire it.. and NO idea how to tune it
    any help would be great!
    I havent forgotten my roots
    86LXItooFAST4me's Avatar
    Austin, Texas
    lol, good luck! but go to http://www.apexi-usa.com/documentation.asp
    Car Pics
    vBGarage
    which one did you get?
    the new ones are little harder to hook up.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Tuning is best left to a tuner, thats what they get paid to do. Find a local shop with a good rep and let them do it, you wont be sorry
    Austin, Texas
    Quote Originally Posted by Vinny
    but thats the easy way Vinny!! why do that when there is the HARD WAY!
    Car Pics
    vBGarage
    do a conservative tune like i did... thatll work just fine (maybe down 5-10hp from a fully tuned setup) but itll prevent you from blowing anything. Which model did you get? Theres at least 6 different ones from what ive seen (1 knob, 6 knob, SAFC I, SAFC II, VAFC I, VAFC II).
    Nov 2001
    huntsville, al
    i got the safc I.
    of course our ecu isnt listed, which cars pinout should i use? the 4th gen ecu is a direct plug in right? use that diagram?
    TUNING: i highly doubt their is anyone in town that actually can "tune", if anyone has already done this...post you map
    there is no direct plug it. you will have all the wires yourself. it took me a few hours to figure out which wire when where.
    and when it comes to tunning, you may want to get wide band O2 sensor and wide band air/fuel gauge. it will help you to tune the mixture almost to perfect condition.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Quote Originally Posted by hondamanlxi
    Do you have the install manual at all?
    If not I suggest you dwonloa d it from their site.
    The accords pinout is the same as the one listed for the b16 teg and civic. just look for the only one that has the same shaped plugs as the Accord.
    The wiring is pretty simple. you tee the wires into the harness except for the map which gets cut and goes into and out of the afc.
    The hard part is getting the rpm signal. I used the tach output of my msd ignition but if you dont have one you have to find the correct tach signal wire in back of the gauge cluster.
    As far as setting it up. I say find someone who can do it. Its so damn long to read through the manual and try and figure it out on your own.plus you could damagfe something.
    Let me tell you this the afc is one of the best little products for Hondas. I have an afc2 and it was worth every penny. Its a must for anyone who wants to get more out of their other wise stock efi system. I had someone locally set it up and with just slight changes in the fuel it made one hell of a difference.
    One thing though, If your not plannig on having someone tune it to your car it might be a waste of time cause you will never see the full benefits and probably dislike the afc. Just keep that in mind. I know good tuners are hard to find but just keep on looking.
    is wiring one of theres to a20a3 work the same as the a20a1 ecu's in the prelude's...or are those ecus not compatable with piggy back systems i donno....?
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Quote Originally Posted by Shady_Pro
    They do not have an ECU, they have a solenoid control unit because it's carbed. So it will not work.
    Link to my 3geez garage
    no man the a20a1 isn't carb'd its efi the a18 is carb'd
    LX User P|eszczoH's Avatar
    Nov 2003
    2 x 1989 Honda Accord Aerodeck 2,0i Exclusive Edition(lather, and one with A/C)
    Warsaw, Poland, Europe
    No You are wrong
    A20A1 and A20A2 are carbed engines.
    A20A3 and A20A4 are Fi engines.
    I had A20A1, A20A2 , and now i have two A20A3 in my Aerodecks and I'm sure of what I'm saying.
    have a nice ride
    P|eszczoH
    LX User Versanick's Avatar
    Jun 2002
    1986 Honda Accord LX Sedan (RIP), 1989 (same) RIP, 86 Hatch Lx-i, JDM b20a, Gude headpkg, AEM cam gears/cai, thermal xhst, 2.5/3" lowrd tokico/groundctrl, 17" Seneca whls, hypereutectic pistons, .020" over, 13:1 comp
    Upstate NY
    Since the effective rev limit in an a20 ECU (pj0) is the cutting of fuel, would an apex S-AFC II be able to set fuel maps for above 7000rpm?
    Would I, by using it, be able to rev to 8000rpm? Or, better, use my MSD 8000rpm pill to rimit my revs? 6950 on my b20a begs to be expanded.
    If you can adjust fuel curves in 500rpm increments, why not 7000, 7500, 8000, where the ECU has no maps beyond 7000?
    Jun 2002
    Upstate NY
    Is there any known way to bypass the ECU's rev limit. I would think a piggyback would be able to feed the ECU whatever signal it needs, then send signal to the injectors and such, and to the ignition...
    or do I need to just give up and get a different ECU?
    LXi User jigga89SEi's Avatar
    Feb 2003
    1999 Subaru Impreza 2.5RS, 2008 Subaru Impreza 2.5i, 1989 Sei(Project Honda SVX)
    Hampton Roads, Va
    Re: apexi s-afc install and settings q?
    Well before cke goes ballistic I'm bringin this thread back for the fact that it has some useful info.. that n the fact that I cant find an answer to my questions anywhere else...
    From what I read the S-afc II can be hooked up to an a3.. But its more difficult... Does anyone actually have one? Or can tell me whats up with it?.. I'm lookin for an S-afc I but I haven't found one yet... I would like to get one because Ive decided I'm gonna do an ITB setup on my N/A engine.. N the cheapest method of control I can figure is an S-afc..
    Anyone have any input?...
    guaynabo89's Avatar
    FL
    Quote Originally Posted by jigga89SEi
    well if I remember corectly it only has like six wires. power, ground, in from map sensor, out to ecu map, tach, and tps.
    All of which can be tapped at the ecu just like your supposed to, except for the tach. For that your going to have to either open up the dash and run a lead from the back of the tachometer to the afc or if you have an aftermarket ignition box with a tach output (msd 6 al etc) you can use that for your afc. This is what I did before I went obd1.
    89T's Avatar
    Apr 2004
    ahh! nevermind.
    pr6 sensor type.
    Feb 2003
    Hampton Roads, Va
    So is this for the model I or II.. N thanx for the info it actually helped alot...
    Now does anyone think I might benifit better with the ITB set-up by runnin a different controller?...
    I've also been lookin at the 4th distro/ n conversion to obd1... Input on this? Pros n Cons? will it benifit or is it just gonna waste time/money?
    Feb 2003
    Hampton Roads, Va
    Double post OWNz Me
    guaynabo89's Avatar
    FL
    This is for afc2
    obd1 is good very involved though car runs soother pulls better in higher rpm.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    would i see any difference putting this on my car with basic bolt-ons?? or would i see better improvements going obd-1 and using crome or something similar??
    -Gio
    My E85 Turbo Build
    5280FEST
    SEi User adams86lxi's Avatar
    86 Honda Accord LXI 5speed
    so cal.
    i have a safc-2 and it serioulsy only took like 20 minutes to wire up. Easy as hell man. The only wire i had trouble connecting up was the one for the rpm signal but i just ran the wire to the negative of the coil and it worked perfect. Just use the book it came with and the ecu pinouts here and its easy as hell. https://www.3geez.com/showthread.php?t=185
    http://www.myspace.com/3364524
    b20accord SN on honda-tech,homemadeturbo,clubcivic,turbod16, and many more
    Feb 2003
    Hampton Roads, Va
    what exactly do u mean by goin obd1? 4g distro? Ecu? I'm a little confused on that...
    A Mile High.
    i mean converting to obd1, using an f22 dizzy and an integra chipped ecu and whatever else i need to convert it, thats what i meant...would this help out a lot for basic bolt ons??
    -Gio
    My E85 Turbo Build
    5280FEST
  1. Koni Red settings
    By carotman in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-29-2008, 03:48 AM
  2. Caster Settings
    By billyballer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-04-2007, 12:11 PM
  3. shock settings
    By Zman in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-01-2004, 09:39 PM
  4. Equalizer settings
    By Kemperz in forum Interior & Exterior Care
    Last Post: 03-24-2003, 07:18 PM
  5. Torque settings for bolts during springs/struts install ?
    By shogun in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-26-2003, 10:33 PM
