Does anyone have an wiring diagram and settings for this? i got a used one for 100 bucks and i have a faint idea how to wire it.. and NO idea how to tune it![]()
any help would be great!
I havent forgotten my roots
lol, good luck! but go to http://www.apexi-usa.com/documentation.asp
which one did you get?
the new ones are little harder to hook up.
Tuning is best left to a tuner, thats what they get paid to do. Find a local shop with a good rep and let them do it, you wont be sorry
do a conservative tune like i did... thatll work just fine (maybe down 5-10hp from a fully tuned setup) but itll prevent you from blowing anything. Which model did you get? Theres at least 6 different ones from what ive seen (1 knob, 6 knob, SAFC I, SAFC II, VAFC I, VAFC II).
i got the safc I.
of course our ecu isnt listed, which cars pinout should i use? the 4th gen ecu is a direct plug in right? use that diagram?
TUNING: i highly doubt their is anyone in town that actually can "tune", if anyone has already done this...post you map
there is no direct plug it. you will have all the wires yourself. it took me a few hours to figure out which wire when where.
and when it comes to tunning, you may want to get wide band O2 sensor and wide band air/fuel gauge. it will help you to tune the mixture almost to perfect condition.
Originally Posted by hondamanlxi
Do you have the install manual at all?
If not I suggest you dwonloa d it from their site.
The accords pinout is the same as the one listed for the b16 teg and civic. just look for the only one that has the same shaped plugs as the Accord.
The wiring is pretty simple. you tee the wires into the harness except for the map which gets cut and goes into and out of the afc.
The hard part is getting the rpm signal. I used the tach output of my msd ignition but if you dont have one you have to find the correct tach signal wire in back of the gauge cluster.
As far as setting it up. I say find someone who can do it. Its so damn long to read through the manual and try and figure it out on your own.plus you could damagfe something.
Let me tell you this the afc is one of the best little products for Hondas. I have an afc2 and it was worth every penny. Its a must for anyone who wants to get more out of their other wise stock efi system. I had someone locally set it up and with just slight changes in the fuel it made one hell of a difference.
One thing though, If your not plannig on having someone tune it to your car it might be a waste of time cause you will never see the full benefits and probably dislike the afc. Just keep that in mind. I know good tuners are hard to find but just keep on looking.
is wiring one of theres to a20a3 work the same as the a20a1 ecu's in the prelude's...or are those ecus not compatable with piggy back systems i donno....?
They do not have an ECU, they have a solenoid control unit because it's carbed. So it will not work.Originally Posted by Shady_Pro
no man the a20a1 isn't carb'd its efi the a18 is carb'd
No You are wrong
A20A1 and A20A2 are carbed engines.
A20A3 and A20A4 are Fi engines.
I had A20A1, A20A2 , and now i have two A20A3 in my Aerodecks and I'm sure of what I'm saying.
have a nice ride
P|eszczoH
Since the effective rev limit in an a20 ECU (pj0) is the cutting of fuel, would an apex S-AFC II be able to set fuel maps for above 7000rpm?
Would I, by using it, be able to rev to 8000rpm? Or, better, use my MSD 8000rpm pill to rimit my revs? 6950 on my b20a begs to be expanded.
If you can adjust fuel curves in 500rpm increments, why not 7000, 7500, 8000, where the ECU has no maps beyond 7000?
bury the bach.
http://home.stny.rr.com/versanick/burythetach
Is there any known way to bypass the ECU's rev limit. I would think a piggyback would be able to feed the ECU whatever signal it needs, then send signal to the injectors and such, and to the ignition...
or do I need to just give up and get a different ECU?
bury the bach.
Well before cke goes ballistic I'm bringin this thread back for the fact that it has some useful info.. that n the fact that I cant find an answer to my questions anywhere else...
From what I read the S-afc II can be hooked up to an a3.. But its more difficult... Does anyone actually have one? Or can tell me whats up with it?.. I'm lookin for an S-afc I but I haven't found one yet... I would like to get one because Ive decided I'm gonna do an ITB setup on my N/A engine.. N the cheapest method of control I can figure is an S-afc..
Anyone have any input?...
well if I remember corectly it only has like six wires. power, ground, in from map sensor, out to ecu map, tach, and tps.Originally Posted by jigga89SEi
All of which can be tapped at the ecu just like your supposed to, except for the tach. For that your going to have to either open up the dash and run a lead from the back of the tachometer to the afc or if you have an aftermarket ignition box with a tach output (msd 6 al etc) you can use that for your afc. This is what I did before I went obd1.
ahh! nevermind.
pr6 sensor type.
So is this for the model I or II.. N thanx for the info it actually helped alot...Originally Posted by guaynabo89
Now does anyone think I might benifit better with the ITB set-up by runnin a different controller?...
I've also been lookin at the 4th distro/ n conversion to obd1... Input on this? Pros n Cons? will it benifit or is it just gonna waste time/money?
Double post OWNz Me
This is for afc2Originally Posted by jigga89SEi
obd1 is good very involved though car runs soother pulls better in higher rpm.
would i see any difference putting this on my car with basic bolt-ons?? or would i see better improvements going obd-1 and using crome or something similar??
i have a safc-2 and it serioulsy only took like 20 minutes to wire up. Easy as hell man. The only wire i had trouble connecting up was the one for the rpm signal but i just ran the wire to the negative of the coil and it worked perfect. Just use the book it came with and the ecu pinouts here and its easy as hell. https://www.3geez.com/showthread.php?t=185
http://www.myspace.com/3364524
b20accord SN on honda-tech,homemadeturbo,clubcivic,turbod16, and many more
what exactly do u mean by goin obd1? 4g distro? Ecu? I'm a little confused on that...
i mean converting to obd1, using an f22 dizzy and an integra chipped ecu and whatever else i need to convert it, thats what i meant...would this help out a lot for basic bolt ons??
