Results 1 to 6 of 6
Thread: Power steering fluid is Leaking!!!
    DX User GBs863drLxi's Avatar
    Jan 2004
    86 Accord Lxi hatchback
    Chicopee,Mass
    Question Power steering fluid is Leaking!!!
    Today, I noticed PS fluid leaking onto the Power steering pulley and down to the belt and A/C compressor pulley. I think it is leaking onto the exhaust manifold as well, because there is smoke coming from under the heat shield, but oil isn't leaking. The PS fluid is definitely coming out of the pump somewhere, but I can't pinpoint it... Please help!!
    What can I do? Is there a seal, gasket, or hose that I am not aware of that needs to be replaced? I read in a post about a hose coming out of the back of the pump and leaking onto the exhaust manifold...where is that hose?
    I don't know what else to ask, so Anybody give me a clue here? I know that the main hose coming from the pump in front of the valve cover is Not leaking, so what can it be?
    Thanks for the help!!!
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    The PS hoses have o-rings on the connectors if I remember correctly, so that could be the problem if you say the pump is leaking... also the bearings could be going... sort of like how the water pump usually likes to die.
    Dec 2003
    Millington, TN
    If it is leaking onto the belt
    Then its the P/S shaft bearing. Its a easy fix the bearing is replaceable which is less than $5.00 or you can buy a new pump $100.
    As for the exhaust are you sure its the P/S. Or could it be leaking from the Oil filter base seal.
    Phil
    DX User TEXANHATCH's Avatar
    1988/honda/hatchback lx-i
    Alvin, Texas
    Just Take It Out
    Hi, I have a leak in my rack and pinion and to avoid replace it. I just cut the P/S belt off. Since then no problem at all, steering wheel a little bit hard but its not a big deal. IN our cars the P/S system can be a pain in the $$.
    Rides:
    88 Honda lx-i hatch 5 sp
    89 Volvo 740 GL
    Last 7 years:
    86 Nissan 200sx/ 71 Beetle/ 88 Escort GT/ 97 Honda Accord/ 90 Nissan 240sx/ 93 Celica GT/ 99 Honda CRV/ 92 Corolla/ 03 Civic/91 Explorer/ 99 Suburban
    A20A1's Avatar
    Sep 2001
    hmm one issue that i ran into was the lack of lubrication to the speedometer cable on the trans... or doesn PS not run thru there? Anyways I assumed my speedo cable burned up over time from lack of lubrication.
    1987 ACCORD LX
    ONTARIO CANADA
    ps fluid dosent oil ur spedo cabel the speed sensor has orings at the top and botom if the botom oring gose then u will get all ur powersteerinfluid in ur trany wich has happend to me and if the top ring gose then u will have a fountin of ps fluid near the firewall
  1. Power Steering Fluid low
    By TEXANHATCH in forum 3geez Accords
    Last Post: 10-05-2004, 01:05 PM
  2. Replies: 10
    Last Post: 06-29-2004, 05:12 PM
  3. Power Steering fluid leaking like a water faucet
    By soljaboy2000 in forum 3geez Accords
    Last Post: 01-12-2004, 02:45 PM
  4. power steering fluid
    By Tref_LXI in forum 3geez Accords
    Last Post: 05-06-2003, 10:22 AM
  5. power steering fluid !
    By ACCORD EX in forum 3geez Accords
    Last Post: 09-23-2002, 12:45 PM
