Results 1 to 3 of 3
Thread: how to advance timing w/ distrubutor cab
    DX User johnypimpin2005's Avatar
    87 Honda accord LXi
    Oconomowoc Wisconsin
    i need to know how to advance my timing?
    shepherd79's Avatar
    Falling Waters, WV USA
    why would you want to advance your timing?
    advancing timing may give you 1-2 Hp if that. it all depends on condition of your engine. advancing timing won't help ya when it comes to performance on stock motor.
    do your self a huge favor, and stop messing with motor. unless you actually bought some perfomance parts like header, new camshaft, and so on and on.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    You don't advance the timing with the distributor cap... you need to loosen the entire distributor then rotate it.
    You're only going to notice a slight increase in low end, but as you get higher in the rpms it's not as helpful.
    If you've noticed a lack in acceleration you might want to check into a tune up and make sure you're pulling the right amount of vacuum to the advance diaphragm on the distributor. Especially important if you're carbed.
    Shep is right though, if you want power look into doing something else.
  1. advance my timing for mpg?
    By rocketman in forum 3geez Accords
    Last Post: 04-22-2011, 05:22 PM
  2. timing will not advance far enough!!!
    By johnwc723 in forum 3geez Accords
    Last Post: 02-24-2004, 06:19 PM
  3. Timing Advance
    By 1989se-i in forum 3geez Accords
    Last Post: 11-16-2002, 03:21 AM
  4. How to advance timing II
    By LX-biker in forum 3geez Accords
    Last Post: 07-22-2002, 07:25 PM
  5. how do i advance timing
    Last Post: 07-15-2002, 03:20 PM
