Results 1 to 12 of 12
Thread: DC Header
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Question DC Header
    Well it's already that the B16/18 intake manifold is compatible with the A20 after minimal modification. So my question is how hard would it be to make the B16/18 DC header fit? I would think that if the intake ports are the same on both the A20 and the B16/18, that the exhaust ports would be as well. Has anyone ever tried this? I know it nearly impossible to get a DC header for the A20 anymore, so it's time to see if we have any other options besides custom.
    -Harvey
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    The exhaust ports on the A20 are vertical. The ports on the B's are horizontal.
    2.0Si User Blue Impact's Avatar
    93 Integra LS-S
    Oroville, CA (it's on some maps)
    But the O2 censors' location are different and that could be a problem. Also, you might have to customize your exhaust pipe for it to fit.
    Quote Originally Posted by k-roy
    Street racing is for idiots.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Quote Originally Posted by SteveDX89
    What does this mean Steve?
    -Harvey
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Quote Originally Posted by Blue Impact
    I figured that, but I wonder how bad it would be...
    -Harvey
    shepherd79's Avatar
    Falling Waters, WV USA
    it won't work. the A20 header has 3 bolts on top and 4 on the bottom that hold the header to the block. and B series headers have 4 bolts on the top and 5 on the bottom.
    PS. what Steve was saying is that the exhaust port on A20 is oval shape and it is vertical, but on B series it is horizontal.
    '85 lude
    houston
    they arent vertical they are just narrow since there is only a single ex valve.
    and that isnt that big a deal except the ports are not equal distance apart like 16valve motors. so you cant even redrill the flange
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Yea cyl 3 and 4 exhaust port sits close together on a20a so it will never work.
    Link to my 3geez garage
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    also the tilt of our motor causes the tilt of the downpipe to be different... so you must take that into account or you'll end up hitting the oil pan or aiming the outlet pipe up towards the floor of the car or down towards the ground depending on the tilt of the motor your getting the header from.
    Exhaust ports whould be easy to fix... I figure 2 - 4 stainless J bends or if you don't ming cuting up the existing header more... then just a single long stainless steel pipe. Just have a vise around so you can reshape the ports.
    There will be a negligable amount of difference in tube length so you shouldn't have to worry about ending up with an unequal length header assuming it was to begin with.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Don't forget about deck height as well.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Ehhhhh fuck it I'll just make a custom one.
    -Harvey
    A20A1's Avatar
    Sep 2001
    Quote Originally Posted by A20A3
    Thats the spirit
  1. new s&s header
    By lostforawhile in forum Restoration & Custom Fabrication
    Last Post: 05-24-2014, 11:28 AM
  2. Wtb header
    By da9 in forum Wanted
    Last Post: 01-20-2010, 12:39 PM
  3. DC header
    By Nio in forum Performance
    Last Post: 01-03-2010, 06:11 PM
  4. New header?
    By Robs89LXi in forum Trading Post
    Last Post: 02-17-2004, 09:11 PM
  5. Need a Header
    By K-MOD in forum Trading Post
    Last Post: 02-17-2004, 09:07 AM
