Results 1 to 11 of 11
Thread: Anybody Have This Problem!?!?!?!? Help!
    DX User bigtymer's Avatar
    1988/Honda/Accord
    Manitoba, Canada
    Cool Anybody Have This Problem!?!?!?!? Help!
    Hey guys, ok i took my 3gee, on a 6 hour highway tip from where i'm at to Grand Forks in ND. It burned and unbeleivable amount of oil. i had to put like 5 fucking thins of oil in it. 5!!!!!! Anybody no what the problem might possibly be??? Any help is great. Thanks Guys!
    True 3Gee
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Did it burn it, or did it leak out? Could be your valve seals going or your rings. Could possibly be leaking from your crank seals, oil filter base, oil pan gasket, or PCV box. Take a look under your car after you drive it and see if there are any puddles. Should give you an idea of where it might be coming from.
    glorious!
    1988/Honda/Accord
    Manitoba, Canada
    i did
    Yea i checked to see if anythign was leaking out of the car. And it is secure, i've had it in my garage for a while, and there has never been any puddles or leaks on the floor. So it's kinda wierd!
    True 3Gee
    '89,lxi hatch,'93 lx civic turbo
    nashville,tn
    Quote Originally Posted by bigtymer
    when you have the car running ,see if there is any smoke coming from the exhaust.blueish=burning oil,black=excessive fuel/oil,grey=possibly coolant
    Talk is cheap,just do it.
    Aug 2004
    89sei
    coastal nc
    magic oil
    check the pcv & the valve cover gasket. hell there cheap just replace it. mine did the same but not 5 qts as i drive 100 miles each way to work each way 5 days aweek. now it only consumes about a gt every oil change (3months) as i use synthic
    89 SEI
    H&R ,Koni's,Tokicos,Brembo's, CAI, Full Pacesetter exhaust, 205/50-15 Kumho's
    LX User phoenxislayer15's Avatar
    1987 Honda Accord Hatch
    Greeneville, TN
    Now that you mention smoke, eerie smoke comes from behind my PGMFI... At least when I open my hood that's where it comes from, I noticed it's coming from underneath too...
    1988/Honda/Accord
    Manitoba, Canada
    yea
    Well i know that there is usually some bluish smoke coming from the tail pipe, usually when it's just running, or i hit the gas while in neutral. The other day i did a carb clean and i had to keep it idling high, so i couldn't let my foot off the gas. i kept it between 2500 and 3500 rpms. and there was a lot of blue smoke shit while i was doing that.
    True 3Gee
    LX User FatDave's Avatar
    Nov 2003
    1993 Accord SE coupe
    Valley park Mo
    stick a fork in that engine...its about done
    Never explain--your friends do not need it and your enemies will not believe you anyway.
    Elbert Hubbard.
    1988/Honda/Accord
    Manitoba, Canada
    rrrright
    The smoke problem is fine now. there is always a lot of smoke when you do a carb clean spray. There's not much coming from the pipe now!
    True 3Gee
    Nov 2003
    Valley park Mo
    under 1 quart in 1500 - 1750 miles is ok, pull a plug out and take a look at it, if its really blow-by the plug will be covered in oil, if the car just smokes on start up its the valve seals, if its all the time like a mosquito fogger its probably the rings
    Elbert Hubbard.
    1988/Honda/Accord
    Manitoba, Canada
    thanx
    Alright, i'll giver a look, and see what i can see. hopefully i can determine what it is and fix the problem.
    True 3Gee
  1. accord lxi idle problem and start problem
    By sonusa in forum EFI Tech
    Last Post: 08-21-2006, 09:05 PM
  2. Replies: 7
    Last Post: 08-11-2005, 04:17 PM
  3. Whats wrong with my car? hesitation problem & starting problem!
    By gsus in forum Classic Honda Community Chat
    Last Post: 08-11-2005, 08:04 AM
  4. Exhaust problem? ( Auto Trans Problem )
    By Jay's89Lxi in forum 3geez Accords
    Last Post: 01-18-2005, 04:24 PM
  5. Cold car accelerating problem and also a temp problem
    By chiller670 in forum 3geez Accords
    Last Post: 12-23-2003, 08:23 PM
