so yah, i started working on it today. first i pulled the pedals out of the parts car. took a bit.., but i finally kinda figured it out, dropped the steering column and whatnot. then i pulled the battery out, along with the tray(don't need it in that car anymore), and then pulled the starter and dist. for easier access. then i put the car up on stands and drained the tranny, then started to pull the cv joints. thats where i ran into the first couple problems. the pinch fork to lower control arm bolt was siezed on the passenger side, so i ended up taking apart the inner joint and that solved that. on the drivers side, the ball joint had a lil trouble popping off, and in the process the threads on it got kinda messed up. anyways, i got that cv joint out, then i pulled the tranny itself. didn't take long at all once i was ready to actually pull it. i then took the shifter and whatnot out. then, i half put the suspension and whatnot back together to roll it out onto the street to pull my 4dr into the driveway. as i was doing that, since the threads on the one balljoint were jacked up, i couldn't get the castle nut on far enough, so the lower control arm kept falling, so i ended up using the jack for the front to steer it, and got it where i needed it. i then pulled the 4dr in the driveway(it was actually driving itslef), and then pulled the pedals on that, as well as the battery and the dist. and starter. then i put that up on stands and called it a night. i should finish tomorrow, cuz i just did the cv joints recently, so i know i'll have no problems pulling those out tomorrow. hopefully the balljoints will cooperate, and putting the pedals in and hooking up the cables and whatnot will hopefully not be too bad. anyways, yah, just thought i'd let you all know how it's going.
