Results 1 to 5 of 5
Thread: Nominations for AOM - December 04
    87accordlxi's Avatar
    Oct 2000
    It's that time again. Nominate your favorite 3geez ride!
    Check out the Rules & Regulations
    All winners in the past year are ineligable for nomination:
    March 04 - OldSchoolSwap
    April 04 - Bloodlust
    May 04 - BITESIZE
    June 04 - 88lxi68
    July 04 - RobT5580
    August 04 - Justin86
    September 04 - carotman
    October 04 - Vinny
    November 04 - Paul Aerodeck86
    Duplicate nominations will be deleted
    Posts made that are not nominations will be deleted
    Invalid nominations will be deleted
    - Joe
    Bloodlust's Avatar
    1989 LXi Coupe (SOLD), 1998 Accord EX
    Line Lexington, PA
    I nominate Mike's89AccordLX. He has done so much work to his 3g and he deserves this more than anything.
    Performance Modifications:
    Weber 32/36 Downdraft Carbuerator Re-jetted to Engine
    Dual Remote Custom Intakes with Tenzo R Filters
    Functional Hoodscoop
    Custom Ram Air Box
    Chrome Air Filter Heat Sheild
    Removed Vacuum Lines and Black Box
    Removed Cruise Control
    Removed Canister Purge
    Rebuilt Cylinder Head
    Pacesetter Header welded over the EGR tubes
    Pacesetter Exhaust System with Thrush Turbo Muffler
    Hi-Flow Cat
    Stainless Steel Flex Pipe
    Pacesetter Adjustable Short Throw Shifter
    Deltacam 272 Grind
    Custom Ported Intake Manifold
    Removed EGR System and have a Custom EGR Plate Installed
    CRANE HI-6S Digital Ignition System w/ Rev limiter
    Accel Super Stock Chrome Ignition Coil
    Crane 11mm Firewires
    NGK Power V Plugs gapped @ .050
    Autometer Air/Fuel Gauge
    Autometer Vacuum Gauge
    Autometer Dual Dash Pod
    Autometer Dual A-Pillar Pod
    Matrix X Voltage Gauge
    Matrix X Water Temperature Gauge
    AutoGauge 4" Tach with Shift Light
    Cobra Radar Detector
    Yokohama Avid T4 Tires
    Optima Red Top Battery
    Spectra Glass Fuel Filter
    Spectra Stainless Steel Fuel Line
    Mr. Gasket Dual Throttle Return Spring
    EBC Sport Brake Rotors (slotted & dimpled)
    EBC Green Stuff Performance Brake Pads
    Appearance Mods:
    JDM Factory Spoiler
    JDM Corner Lights
    JDM Blinker Lights
    Painted Taillights Candy Apple Red
    4G Accord Climate Controls Modded to the 3G
    Accord Factory Bra
    Custom Front Bumper Grille
    Procarparts Reverse Glow Gauges
    Procarparts Clear Bumper Signals
    Procarparts Carbon Fiber Gauge Bezel
    Grant Turbo Steering Wheel
    Momo Steering Wheel Hub
    Ichibahn Alluminum Oil Cap
    Ichibahn Alluminum
    Ichibahn Alluminum Carbon Fiber E-Brake Handle
    Ichibahn Carbon Fiber Shift Boot
    SE-i Factory Armrest with Cupholders
    Ventshades
    1991 Prelude Si Front and Rear Seats (4 bucket seats)
    Shaved Emblems
    ACCORD Emblem on the dash
    Powdercoated Chrome Valvecover
    Powdercoated Chrome Custom Intake Manifold
    Powdercoated Chrome LX-i Thermostat Housing
    Red Wire Loom
    Headlight Relays
    H4 Headlight Conversion
    Xenon bulbs
    Carbon fiber look gas door
    Uni-wiper w/carbon fiber look wiper blade
    Spectra Stainless Steel Hose Sleeves
    OBX Chrome Type R Pedals
    Accord Type R Seat Belt Pads (Front and Rear Seats)
    Mugen Resevoir Tank Covers
    Audio & Security:
    Avital Security
    Kenwood Excellon HU
    Kenwood Excellon 6.5" speakers (4 total)
    Kenwood Excellon 2x 12" Subs
    Kenwood Excellon 4 channel 650watt amp
    Kenwood Excellon 2 channel 1000watt amp
    Custom Dual Sub Box
    Stinger Platinum Battery Terminals (+/-)
    Stinger Speaker Wire
    Stinger Spiral 4 channel RCA wires
    2 Gauge Amp Kit
    Suspension:
    Front & Rear Sway Bars Sei
    Custom rear strut bar
    17" Team Loco 140's with Kumho Tires.
    Tokico 1" drop springs and wishbone 1/2" drop mod
    Tokico Blues Struts
    EFI Conversion in the works and SEi front and rear disc swap too.
    Thinking about getting a new 3g...
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    I nominate Justanothermike. His coupe is an inspiration to me and anyone else that's trying to build an all-motor A20A3.
    Justanothermike's 88 Honda Accord LXi Coupe
    Engine:
    83.7(+1mm overbore)x91mm A20a3 Single cam 12 valve
    10.5:1 compression welded Head
    P&P Head and B16a manifold 63mm LS TB
    256/270 reground camshaft
    290/.430 race cam
    Golden Eagle Cam Gear
    H22 Injectors
    DC sports header
    8lb aluminum flywheel
    Hybrid close ratio transmission
    Hondata S100 P75 OBD1 Ecu
    MSD 7AL2, MSD coil
    140WHP and 116WTRQ on DSR's Dyno Jet before rebuild stock block/head
    Suspension:
    Progress sport springs
    Koni Reds
    Suspension Tech Swaybars
    GSR rims
    -Harvey
    SEi User od2681's Avatar
    Nov 2002
    2003 Infiniti G35 sedan
    Houston Tx
    i nominate A20A1
    basically for all the custom work he does...although he doesnt have thee nicest lookin car, it deserves to be nominated...
    SUSPENSION MODS:
    - ACE 15" CYCLONES (YES 15's... I'll only go larger to get larger brakes... but I'm not in the market for either, 15's is well suited for all round racing, no bling bling here bubbies.)
    - DUNLOP SP Sport Tires
    - MAXSPEED 90-97 CO's
    ENGINE MODS:
    COLT CAMS 280/288 Regrind
    - Lubed by VR1 20w-50
    -- Filtered by K&N GOLD
    --- Increased Oil PSI
    ---- Mildly Strict 4000-7500rpm powerband
    ----- Pulling a lowsy 8-10" vacuum max @ 1000rpm Idle
    High duration/overlap frickin blows
    but shooting flames out the carb when you get a reversion pulse is badass
    2 B&M Trans oil coolers
    - Running on TRICK SHIFT & MOBIL 1 ATF
    WEBER DGV (CARB IS TOO SMALL)
    - Running on 89 Octane
    -- Filtered by FRAM
    --- Still not jetted right
    ---- Made a 1" carb spacer for Carb
    CUSTOM 4-1 CIRCLE TRACK HEADER
    - Mild Steel
    -- 3" Collector
    --- Coated with ceramic paint
    ---- Currently fitted with a 2" Muffler for daily driving
    BOSCH Platinum +4's
    ACCEL SUPER COIL
    ACCEL CUSTOM WIRE SET
    OTHER MODS:
    CUSTOM HOOD SCOOP
    JDM TAIL LIGHTS
    ROUND TAIL LIGHTS
    RELOCATED BATTERY TO FIREWALL
    INTERIOR MODS:
    MOSTLY STRIPPED INTERIOR
    CUSTOM DASH W/ ONE MOUNTED AUTOMETER 8K RPM TACH GAUGE
    IN THE WORKS
    - 390 CFM 4BBL or 500 CFM 4BBL
    - CUSTOM 4BBL DIVIDED PLENUM INTAKE MANIFOLD
    - UPGRADED FUEL PUMP ( CARTER SUPER STREET PUMP )
    blazin3gen's Avatar
    Good Ol Cali
    i nominate derek * busted_blue cuz hes so sick wit it yo!
    Engine:
    MSD 6A
    Neuspeed 9mm wires
    90-93 Integra CAI
    dc sports header
    Suspension:
    SEi rear disc conversion
    Tokico H.P. struts
    Suspension Techniques F+R sway bars
    Techna-fit stainless steel brake lines
    Exterior:
    OEM "I <3 My Honda" Static Cling
    OEM window visors
    OEM sunroof visor
    OEM 1995 Integra GSR rims
    Falken Ziex 512 size 205/50/15
    Projector foglights with yellow inserts
    Interior:
    OEM LXi optional blue armrest
    OEM SEi cupholders
    OEM 98-02 Accord floormats
    Skunk2 440g shift knob
    Air Spencer CS-X3 air freshener
    Misc:
    JDM Honda Asimo plush doll
    Waiting To Be Installed:
    Koni Special struts (front)
    DC Sports header
    Projects Yet To Venture On
    Integra Hybrid tranny
    Exhaust
    Custom strut bars
  1. Accord of the Month Nominations: December
    Last Post: 11-14-2008, 01:07 AM
  2. Accord of the Month Nominations - December 2007
    Last Post: 11-12-2007, 08:15 PM
  3. Nominations - December Accord of the Month
    Last Post: 11-06-2006, 11:40 PM
  4. Accord of the Month Nominations: December
    By NXRacer in forum Accord of the Month Archives
    Last Post: 11-05-2005, 04:52 PM
