I have it running pretty good right now but am having the following issues.
Note I have vac line 18 blocked, because I broke the platic nipple it plugs into. Also have one other vac line plugged, more detail on that later. NO vac leaks that I can find.
Hard to start when cold, when it does start, it doesn't idle up like it used to. Choke problem?
After it was running for a bit this moring, it wanted to idle a little high?
The timing is off by one tooth, I cant get it to goto TDC when using a timing light and adjusting the distributor all the way down. Is it possible to correct this on the dist end or o I have to take the belt off and move it? Tips on this appriciated...
Last one, it doesn't have as much power as it used to above 3-4 grand. It used to really start kicking in around that range... No longer...
