Alright I did it and the damn car is still sitting w/out me driving cuz now I can't get the starter in; the plate it sits on is different so hopefully I can just get it and swap my old starter onto it
tools: 10, 12, 14, 17, 19mm sockets or wrenches w/ assorted extensions, u-joints, breaker bars, whatever else you want to bring. If you're dropping the steering column the 12 has to be a deep socket. A jack for raising up the car, removing/installing the trans. Jack stands. Oil drain pan and 3 quarts of motor oil 10/30-20/50 whatever. I'd get the thicker one, it gets so hot in there anyways. Strong diagonal cutters will come in handy.
1. need the following:
engine bay: tranny (make sure it has the reverse light hookup wires coming out the front) clutch, flywheel, pressure plate, rear mount bracket (the black thing with 3 holes on the side... the rubber mount is the same) clutch cable, starter.
interior: boot and knob, pedals (with switches), shifter hole cover plate assembly (lol I swear I didn't make that up )
Optional: Fuel Gauge w/out gear lights, M/T driveshafts, Carbs: Get the throttle control vacuum 1-way valve from the 5speed also and note how it's hooked up. The automatics have that port available with a plug. It needs a constant vacuum tap. not a requirement.
Take care to note: The auto trans has a great center of balance on the jack, the 5-speed fell over like 4 times, get help for reinstalling it. Cruise control cars have an extra pair of pins on the brake switch, the accelerator cable is also different but that's not necessary to swap. To change the pedals it is easier to take out the steering column first (also have someone hold the booster from the engine bay for you or pull on the actuator rod from the inside as you put the pedals on it). Installing the tranny with the shift rods on it is going to be damn near impossible, unbolt them from the tranny and install them first to the center hump. The automatic neutral/park start wires need to be either jumped or connected to the clutch pedal switch. The reverse lights wires (2) need to be run into the car and connected to the auto trans gear selector wiring harness. I think the axles are the same, they both connected fine. I dunno how you all fill your trannies but I filled it through the power steering/speedo cable gear. Oh also you can crank up the ignition timing some more now that it's stick but #1 I doubt the automatic distrib has the range of the 5-speed one and #2 I haven't tried out the car yet so I dunno if you can max it out listen for rattling pistons
BTW at the end I ended up getting the boring ass A6 or whatever trans off an 87 DX cuz the other 5-speed at the yard had 250k on it, this one only 151k. Whenever I swap the cluch I'll throw on a 1-2-3 from a Teggie. I'm off to get that starter bracket I'll let you all know how it goes. If anyone has some C4 I have an auto trans that can use an exploding.
