If so.. what are the spring rates?
If you don't know how to read the spring rates they should (hopefully) be listed on the spring portion of the coilover assembly. There should be a set of 3 or 4 numbers that are separated by a period. Please post em up.
BTW.. not sure if they make these for the 3rd gen that's why I'm asking. A softer spring rate for the 4th gen Accord will work nicely on ours.. (example: 400lbs spring rate coilover will be nice and stiff but not too stiff for a 3rd gen but 800lbs would be unbearable)
