Results 1 to 12 of 12
Thread: pgm-fi light blues
    LX User sofaking_bob's Avatar
    Jun 2004
    86 Accord lx-i h/b
    Clanton, AL
    pgm-fi light blues
    so i've had my car worked on a few times this month because the freakin pgm light keeps coming on.. messing with my gas mileage and making the engine studder... things of that sort.. but we've replaced the o2 sensor, the cooling system has been redone and now it's flashing that the erg valve is bad.. or something.. code 12 i think. but the local mechanic says that the 86 accord lx-i was the first fuel injected honda in the states and that the computer chip in it is just really stupid.. it will flash things that just aren't right and that it will nickle and dime you to death, but.. when this light comes on.. my car studders when idle and revs up and down if my foot is not on the gas.. so should i have the egr replaced or is my mechanic right?
    "choose the form of the destructor"
    find the car here:
    http://www.cardomain.com/id/sofaking_bob
    your mechanic is an Idiot. get a new one mechanic.
    if you have code 12, you need to replace or clean the EGR valve. they can get sticky with all that carbon build up. make sure you reset ECU after you replace it.
    LXi User buds302's Avatar
    Jun 2004
    90 civic hb R.I.P. , 2002 EBP EM2<<figure it out..its not that hard
    new castle pa
    Change The Fuel Filter!!!!!!
    b u n n y · t y p e R
    "the bunny liked the go-faster stripes... but wasn't too keen on the rear spoiler and ridiculous bodykit"
    86LXItooFAST4me's Avatar
    Austin, Texas
    when the light comes on does your RPM jump at idle?
    Car Pics
    vBGarage
    Jun 2004
    86 Accord lx-i h/b
    Clanton, AL
    Quote Originally Posted by 86LXItooFAST4me
    yes it does.
    find the car here:
    Austin, Texas
    mine was doing that because of a coolant problem. see your ecu has a primary and secondary program settiing. one is for when your car is warrming up to ideal temp, its basically the default setting i think. the other is the setting your ECU programs itself to. ( thats why you reset your ECU, so it can program itsself to the way the car is running. the other one stays the same for warming up perpuses). so mine was doing that because of the temp sending unit. it wasnt reading any temp on the sensor and threw the ECU all off. it ran fine untill it got warm, then the other setting kicked in and the light turned on and my RPMs jumped. how is your temp when its doing this? i know you redid the coolent sys but whats it reading while the light is on?
    Car Pics
    vBGarage
    Jun 2004
    86 Accord lx-i h/b
    Clanton, AL
    the temp is normal i think. but i think that the mechanic just didn't know what he was talking about. didn't know to reset the ecu after having worked on it and didn't know what the codes meant. so i'll have the egr replaced and tell them to reset the ecu so that things are fine and dandy. yeah... thanks a bunch.
    find the car here:
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    Just a suggestion, change it yourself, if you have enough time I mean, it will get you aquinted (sp) with your car, and they aren't to bad to change. To reset your ECU, all you have to do is pull a fuse and or discounect your ground cable I belive.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
    Hackensack, NJ
    Quote Originally Posted by sofaking_bob
    Did you solve your problem? I had your same problem so I thoroughly cleaned out my EGR valve and 1 week later my check engine light is back showing code 12 again. When the light comes on, it idles at 1500 RPM. Not good.
    SEi User Low Tek's Avatar
    lookin
    Portland Oregon
    hatchback_racer is havingthe same deal
    'honda makes people happy'
    Jun 2004
    86 Accord lx-i h/b
    Clanton, AL
    Quote Originally Posted by superdesi
    i haven't sloved my problem yet, but i'm probably going to be replacing the engine soon. which would slove it.. or at east i hope so. i think code 12 was like the oxy sensor or something like that. but my car is stationary right now clutch is messed up and the engine is leaking.
    find the car here:
    Hackensack, NJ
    An engine rebuild would definately somewhat help the problem. As far as my 3rd Gen, I donated it to my mother's friend the beginning of this year. I just did not want to deal with the hassle, time, energy and money anymore.
  1. got the 3ed gen blues
    By Accord/Viger Ca5 in forum Newbie Introductions
    Last Post: 01-23-2013, 09:14 AM
  2. Tokico blues
    By davidshonda in forum For Sale
    Last Post: 01-28-2011, 01:21 AM
  3. junkyard blues
    By gp02a0083 in forum Classic Honda Community Chat
    Last Post: 05-01-2005, 06:46 PM
  4. Tockico Blues
    By B16 ED9 in forum Trading Post
    Last Post: 02-14-2004, 07:13 PM
  5. tokico blues
    By Neuspeed87lx in forum Trading Post
    Last Post: 12-20-2003, 02:01 PM
