Results 1 to 15 of 15
Thread: Stuck in park
    Thumbs down Stuck in park
    Hmm.. sometimes... like a couple of minutes ago, the car gets stuck in park. I went to get my coat from work, come back, step on the brake to take it out of park, and the button won't go in... if I shut everything off that makes noise an listen, usually it makes a clicking noise when I'm in park an step on the brake, an it works, but when it doesn't work, its doesn't make the clicking noise.. anyone got any thoughts or experienced this themselves?
    DX User gmech's Avatar
    Dec 2003
    1989 Honda Accord /944 Porsche Turbo/2001 Mercedes SLK 320
    IL
    Dear Gundamevo,
    This sounds like a typical cold sticking shift-lock solenoid. Its a common problem for 3G AT Accords, as well as other makes and models.
    Try Removing the center console and then clean and lubricate the solenoid.
    I've included some links below that might prove helpful. Good luck and write back and let us know how things go:
    - Gmech
    http://www.cybertrails.com/~bestinth...dShiftKey.html
    http://www.panix.com/~karlward/info/...sol_usenet.txt
    http://www.realcaraudio.com/forums/a...pic/13316.html
    On all Accords, the transmission/transaxle is equipped with a key shift interlock system. The shift interlock system prevents the shifting lever from being moved from the park position unless the brake pedal is applied and the accelerator is in the idle (foot off pedal) position. If something happens to one of the components the shifter lever interlock system you can override the system by placing the ignition key in the key slot near the shift lever. The shift key lock interlock system prevents the ignition key from being removed from the ignition lock/switch assembly unless the shifter lever is in the park position.
    haha.... so the only real problem with my car is the stupid shift interlock system lol, stupid thing... but maybe not, cuz the key only get stuck when its cold. haha, I jus dropped someone off, an I was in their driveway, it was in park, it was stuck, so I went to get my key out of the ignition and it was stuck, so I had to jiggle the key for 5 minutes lol
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    not all are, my 86 did'nt have it..
    but my lxi did,
    ****** 1994 nissan maxima SE ******
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I removed the solenoid along with the bit that blocks the button from being pushed.
    If the key is stuck sometimes its the steering wheel position... I just turn it side to side till the key comes out. but not far enough to lock the steering wheel or you have to turn the car back on again to unstick it.
    This morning I pulled up to school... put it in park, an as usual I noticed the park light didn't come on, I try taking it out of park an its stuck of course.... so I jus sat in the car for a couple minutes, spun the wheel a lil bit, an then I fixed it and was able to get the key out... I'm gonna tear the car apart yay!!!
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    The problem is the switch that senses it's in park. When it gets cold the old greese that's on the spring loaded contact moves slowly or not at all. If the park contact does not make you cannot pull your key out of the ignition. The way to correct this is to take the console apart and cleand the contacts and re lub them. This is a very common problem with auto trans.
    get the 86-87 selector assembly if you are not too technically inclined, it'll bolt right up and it doesn' have a shift lock, you can put it in park at 90 mph if you want.
    But if you can, i'd do what mike said, just remove the solenoid all together and don't shift out of park when you're not ready that's it. Only reason for that part is old people!
    Eric
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Removing the solenoid will not solve the problem if it's the position sensing switch causing the problem. You still will not be able to remove your key from the ignition unless you fix the sticking shift position switch.
    for real? Daaam my car is Old Skool! I remember a few times needing something from my glove box (I kept it locked) and while still rolling down the street at 40 I would put the tranny in "N" and turn off the ignition, reach over, unlock, start back up, throw it in "D4" and keep going. Just don't try to turn the wheel when u do that! lol
    He's right if it locks your keys then check those contacts out, or I'm sure there's a way to disconnect the key lock feature
    Eric
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    It's pretty simple to remove the console cover to get to the switch assembly. Pobably the easiest way to fix the problem.
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    Quote Originally Posted by POS carb
    lol, i've done stuff like that too. as far as i know, the 89's were the only ones that required you to be in park to remove the key, cuz my '88 had no problem.
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    Can't quite figure this stuff out... stupid me... arg..
    so0o0o0o pretty much I am supposed to take the 4 screws off around the shifter that hold the plate on top of it, an then clean off the old grease somewhere, an put new white grease?? arg... help.... blah I have a 600 dollar car insurance bill next wednesday to pay off for the year... and like... I still have to do the brakes, rotors, oil change, tune up, alignment, and snow tires b4 it starts snowing, stupid insurance company, I could get all this shit done now.. but they want me to pay for this month, december, and january now... oh well...
    chicago , il.
    i think it cmes in handy...
    the other day at the j/y a teg was rolling backwards....
  1. well i went to jurrasic park guys.
    By danny nr crew in forum Classic Honda Pics & Videos
    Last Post: 09-03-2011, 01:11 AM
  2. park light question
    By import racer in forum EFI Tech
    Last Post: 03-11-2009, 05:45 AM
  3. my wipers do not park, what is wrong?
    By lamontlamont in forum 3geez Accords
    Last Post: 07-13-2007, 11:35 PM
  4. windshield wipers won't park
    By jayshonda in forum 3geez Accords
    Last Post: 02-21-2005, 01:44 AM
  5. no park !!!
    By lewis74 in forum 3geez Accords
    Last Post: 06-01-2003, 05:53 AM
