Results 1 to 4 of 4
Thread: bent valves?
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    bent valves?
    how do u know if u have a bent valve? i heard that if your timing belt breaks it can bend a valve. my car was idling when the timing belt broke, but that was like 4 months ago. and no problems that i know of yet (except for a hesitation problem which i think is my spark plugs)
    88 Lxi/ 5spd
    Tennessee
    you will definitely hear a strange noise depending on how bad bent it is. Idling is the super duper best time to break the timing belt if any cause valves ain't shooting around too fast. A bent valve should also screw up the guide and cause the car to burn oil really bad
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    mantis, you dont have bent valves
    I havent forgotten my roots
    1989 accord lxi
    definately not, yer valves are fine, and a word to everyone, check yer timing belt when your change yer oil.
  1. More then likely bent my valves
    By Nio in forum 3geez Accords
    Last Post: 01-18-2010, 04:28 PM
  2. I need a fast answer about bent valves!!!
    By aerokid1987 in forum Classic Honda Community Chat
    Last Post: 05-30-2006, 07:06 PM
  3. bent frame
    By cmzinner in forum 3geez Accords
    Last Post: 02-23-2004, 08:48 PM
  4. Bent Valves???
    By Dizzo7693 in forum 3geez Accords
    Last Post: 08-13-2003, 11:10 AM
  5. mandrel bent?
    By 89AccordHatch in forum Performance
    Last Post: 12-25-2002, 09:25 PM
