THIS THREAD IS FOR VOTING ONLY. If you have any questions/comments, please direct them to the appropriate person.
This month's contestants are:
Mike's89AccordLX
Justanothermike
A20A1
Busted_Blue
Good Luck!
Mike's89AccordLX
Performance Modifications:
Weber 32/36 Downdraft Carbuerator Re-jetted to Engine
Dual Remote Custom Intakes with Tenzo R Filters
Functional Hoodscoop
Custom Ram Air Box
Chrome Air Filter Heat Sheild
Removed Vacuum Lines and Black Box
Removed Cruise Control
Removed Canister Purge
Rebuilt Cylinder Head
Pacesetter Header welded over the EGR tubes
Pacesetter Exhaust System with Thrush Turbo Muffler
Hi-Flow Cat
Stainless Steel Flex Pipe
Pacesetter Adjustable Short Throw Shifter
Deltacam 272 Grind
Custom Ported Intake Manifold
Removed EGR System and have a Custom EGR Plate Installed
CRANE HI-6S Digital Ignition System w/ Rev limiter
Accel Super Stock Chrome Ignition Coil
Crane 11mm Firewires
NGK Power V Plugs gapped @ .050
Autometer Air/Fuel Gauge
Autometer Vacuum Gauge
Autometer Dual Dash Pod
Autometer Dual A-Pillar Pod
Matrix X Voltage Gauge
Matrix X Water Temperature Gauge
AutoGauge 4" Tach with Shift Light
Cobra Radar Detector
Yokohama Avid T4 Tires
Optima Red Top Battery
Spectra Glass Fuel Filter
Spectra Stainless Steel Fuel Line
Mr. Gasket Dual Throttle Return Spring
EBC Sport Brake Rotors (slotted & dimpled)
EBC Green Stuff Performance Brake Pads
Appearance Mods:
JDM Factory Spoiler
JDM Corner Lights
JDM Blinker Lights
Painted Taillights Candy Apple Red
4G Accord Climate Controls Modded to the 3G
Accord Factory Bra
Custom Front Bumper Grille
Procarparts Reverse Glow Gauges
Procarparts Clear Bumper Signals
Procarparts Carbon Fiber Gauge Bezel
Grant Turbo Steering Wheel
Momo Steering Wheel Hub
Ichibahn Alluminum Oil Cap
Ichibahn Alluminum
Ichibahn Alluminum Carbon Fiber E-Brake Handle
Ichibahn Carbon Fiber Shift Boot
SE-i Factory Armrest with Cupholders
Ventshades
1991 Prelude Si Front and Rear Seats (4 bucket seats)
Shaved Emblems
ACCORD Emblem on the dash
Powdercoated Chrome Valvecover
Powdercoated Chrome Custom Intake Manifold
Powdercoated Chrome LX-i Thermostat Housing
Red Wire Loom
Headlight Relays
H4 Headlight Conversion
Xenon bulbs
Carbon fiber look gas door
Uni-wiper w/carbon fiber look wiper blade
Spectra Stainless Steel Hose Sleeves
OBX Chrome Type R Pedals
Accord Type R Seat Belt Pads (Front and Rear Seats)
Mugen Resevoir Tank Covers
Audio & Security:
Avital Security
Kenwood Excellon HU
Kenwood Excellon 6.5" speakers (4 total)
Kenwood Excellon 2x 12" Subs
Kenwood Excellon 4 channel 650watt amp
Kenwood Excellon 2 channel 1000watt amp
Custom Dual Sub Box
Stinger Platinum Battery Terminals (+/-)
Stinger Speaker Wire
Stinger Spiral 4 channel RCA wires
2 Gauge Amp Kit
Suspension:
Front & Rear Sway Bars Sei
Custom rear strut bar
17" Team Loco 140's with Kumho Tires.
Tokico 1" drop springs and wishbone 1/2" drop mod
Tokico Blues Struts
EFI Conversion in the works and SEi front and rear disc swap too.
Justanothermike
Justanothermike's 88 Honda Accord LXi Coupe
Engine:
83.7(+1mm overbore)x91mm A20a3 Single cam 12 valve
10.5:1 compression welded Head
P&P Head and B16a manifold 63mm LS TB
256/270 reground camshaft
290/.430 race cam
Golden Eagle Cam Gear
H22 Injectors
DC sports header
8lb aluminum flywheel
Hybrid close ratio transmission
Hondata S100 P75 OBD1 Ecu
MSD 7AL2, MSD coil
140WHP and 116WTRQ on DSR's Dyno Jet before rebuild stock block/head
Suspension:
Progress sport springs
Koni Reds
Suspension Tech Swaybars
GSR rims
A20A1
SUSPENSION MODS:
- ACE 15" CYCLONES (YES 15's... I'll only go larger to get larger brakes... but I'm not in the market for either, 15's is well suited for all round racing, no bling bling here bubbies.)
- DUNLOP SP Sport Tires
- MAXSPEED 90-97 CO's
ENGINE MODS:
COLT CAMS 280/288 Regrind
- Lubed by VR1 20w-50
-- Filtered by K&N GOLD
--- Increased Oil PSI
---- Mildly Strict 4000-7500rpm powerband
----- Pulling a lowsy 8-10" vacuum max @ 1000rpm Idle
High duration/overlap frickin blows
but shooting flames out the carb when you get a reversion pulse is badass
2 B&M Trans oil coolers
- Running on TRICK SHIFT & MOBIL 1 ATF
WEBER DGV (CARB IS TOO SMALL)
- Running on 89 Octane
-- Filtered by FRAM
--- Still not jetted right
---- Made a 1" carb spacer for Carb
CUSTOM 4-1 CIRCLE TRACK HEADER
- Mild Steel
-- 3" Collector
--- Coated with ceramic paint
---- Currently fitted with a 2" Muffler for daily driving
BOSCH Platinum +4's
ACCEL SUPER COIL
ACCEL CUSTOM WIRE SET
OTHER MODS:
CUSTOM HOOD SCOOP
JDM TAIL LIGHTS
ROUND TAIL LIGHTS
RELOCATED BATTERY TO FIREWALL
INTERIOR MODS:
MOSTLY STRIPPED INTERIOR
CUSTOM DASH W/ ONE MOUNTED AUTOMETER 8K RPM TACH GAUGE
IN THE WORKS
- 390 CFM 4BBL or 500 CFM 4BBL
- CUSTOM 4BBL DIVIDED PLENUM INTAKE MANIFOLD
- UPGRADED FUEL PUMP ( CARTER SUPER STREET PUMP )
Busted_Blue
Engine:
MSD 6A
Neuspeed 9mm wires
90-93 Integra CAI
dc sports header
Suspension:
SEi rear disc conversion
Tokico H.P. struts
Suspension Techniques F+R sway bars
Techna-fit stainless steel brake lines
Exterior:
OEM "I <3 My Honda" Static Cling
OEM window visors
OEM sunroof visor
OEM 1995 Integra GSR rims
Falken Ziex 512 size 205/50/15
Projector foglights with yellow inserts
Interior:
OEM LXi optional blue armrest
OEM SEi cupholders
OEM 98-02 Accord floormats
Skunk2 440g shift knob
Air Spencer CS-X3 air freshener
Misc:
JDM Honda Asimo plush doll
Waiting To Be Installed:
Koni Special struts (front)
DC Sports header
Projects Yet To Venture On
Integra Hybrid tranny
Exhaust
Custom strut bars
