i've been working to restore this old engine and there're afew issues left i haven't found in search...for one, i gotta get rid of startup smoke (used to be evaporated antifreeze from warped head before block sealant job, now oil) that my grandad said could be valve guides (oil seeping into combust. chamber through these). but my dad said since it doesn't blow smoke as much after super cold nights(oil thickens), he thinks that the oil seeping out of valve cover gasket (about to replace this) is leaking into the plugs...i'd like to know if this is possible...?
also...tach needle frequently drops to zero for afew seconds then corrects itself. (heard of random jumping but this?)
this car's got 360,000 in it, if i fix it i can drive it...much thanks yall.
...also have general electrical, low-idle/stall, loose clutch, and overall compression issues but i think i found threads for these.
the newb,
ty
