Has anyone done this conversion? I already have an 88/89 2 stage intake manifold and I want to know if it is easier to change the wiring, vacuum lines, ecu, etc to make this work on my 87 lxi, or to adapt the newer manifold to work with the existing setup using an rpm activated switch to control the butterfly valves...By the way, I know this manifold is worth 10 hp compared to the 86/87 style, and mine has been ported (as well as modified to accept 4 additional injectors to work with my turbosystem) so it should be worth a little more hp. If you know about this conversion, let me know, don't hold the 3g back!
