Results 1 to 13 of 13
Thread: WTF? Squeaky belts.
    89 Accord LX-i
    Central Oregon
    WTF? Squeaky belts.
    First I've searched, and tried previous suggestions on this matter with no luck. My alternator belt is squeaking like a mutha, and it's annoying as hell. The belt is new, however I'm not 100% sure it is the correct belt because when I put it on, I pushed the alternator all the way forward towards the block and still had to kind of pry it on the pulley. Now, I adjusted the tension, and drove it about 2 hours, and the belt was loose again, so I adjusted it again as tight as I could get it. Now with it like this, the belt squeels non stop. There is alot of rubber "shavings" all over, so I thought the pulley's may not be aligned, but I do not see how that is possible. Tonight I loosened the belt a little, and it wouldn't charge the battery afterwards, so I have it as tight as possible again, but it's still squeeling. I've used some belt dressing but that only stops it for approximately 30 secs. Anyone have some suggestions? Thanks for yor time.
    "Without high school drop-outs,
    some guys would starve"
    Easy Money
    LXi User buds302's Avatar
    Jun 2004
    90 civic hb R.I.P. , 2002 EBP EM2<<figure it out..its not that hard
    new castle pa
    pour sprite on the belt while its runnin. whatch out you dont get sprayed. soda in the eye aint fun. check to see if the belt is rubbin the lower timing belt cover. also some times new belts arent made right and they have to wear down a little until they set in right. also the belt bein loose after you put it on. it cause the belt stretched when it heated up. thats normal. well it happens to me alot. i reccomend you go buy another belt just in case this one is deffective. dont use it unless the other belt breaks or something. once the belt is right and it aint goin no where then you can return the one you bought as a spare or keep it around as a spare
    b u n n y · t y p e R
    "the bunny liked the go-faster stripes... but wasn't too keen on the rear spoiler and ridiculous bodykit"
    89 Accord LX-i
    Central Oregon
    Would the tension being too tight cause it to squeak? I know it being too loose would cause squeaking, but I've never heard of it being to tight and squeaking? Also, what does Sprite do to the belt? I don't want to risk screwing up my Alt by doing that.
    Easy Money
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    you do have the spacer/washer between the alt and alt bracket right? if not the alt is going to be off line. also if nothing seams to work you might wanna check your water pump.
    ps- you want the belt to be really tight but not so much it will kill bearings.
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    Andrew's Avatar
    Jul 2003
    1988 Honda Accord LX
    Vancouver, BC
    I had the same problem awhile ago and discovered that it was the bearing in the alternator, changed the alternator, problem fixed.
    http://www.cardomain.com/memberpage/396598
    Is it just my imagination or does Kalimari kinda look like deep fried assholes?
    89 Accord LX-i
    Central Oregon
    It's a new Alternator and H20 Pump is new also. I never emoved a washer/spacer when I removed the old Alt. Is it on the upper or lower bracket?
    Easy Money
    Dec 2003
    Austin, Texas
    Here go:
    Check out #13
    PS- i went threw 3 ALT and a water pump before i figured this out.
    Car Pics
    vBGarage
    Jun 2004
    new castle pa
    sprite is really sticky when it dries. it might stop the slipping on the pulley. dontworry its not gonna make things worse if thats what your worried about. also check to see if your crank pulley is tight. my belts started to squeal and thenthe next thing you know the crank pulley flew off. i was like i never touched it before. and i changed my alt belt in the parking lot of the auto pats store. it was squealing it ass off and this dude walked over with a bottle of sprite he was drinkin and poured it on the belt and it was like a miricale it just stopped squealin like that. so try it and see what happens
    89 Accord LX-i
    Central Oregon
    I'm still having problems. As I said before, I never had that spacer, but I pulled the belt off and there was alot of wear on the side of it(looked like an extremely worn radial tire), so I think that may be a problem. Also, the belt and pulley's were extremely sticky, so I don't see how it's slipping, especially with all the tension. Any other idea's, other than that spacer? And where can I get a part # for that? Local parts stores employ some really idiotic people that can't seem to get me the right parts, so if I know the part # and manufacturer, Maybe I'll get the right part! Oh yeah, when I was comparing the new and old belt, there were some numbers on it, but they didn't match. I think the old one said something like 395 and the new one said 390, is that the circumference in mm or something?
    Easy Money
    LX User ehulst's Avatar
    Mar 2004
    1986 Accord DX( RUST IN PEACE) NEW ACCORD 93 LX COUPE 5spd
    Maine
    one of my belts is doing the same thing.....i start the car up and it screams at me.......i had to pull my ear away from inbetween the valve cover and air box cause it was so loud.....
    ATOMICSNOWBOARDING.com
    ACCORD(rust in peace)
    93 accord pics soon be uploaded
    89 Accord LX-i
    Central Oregon
    Grrrr.... OK, I LOOSENED the belt, and it stopped squeaking, and stopped charging my Battery. If I TIGHTEN the belt, it still squeaks like a mofo. Any other idea's?
    Easy Money
    DeathRat's Avatar
    Aug 2003
    95 Chev C1500 Truck / 90 Cavalier Coupe (sold)/ 88 Accord LX Sedan (sold)
    Edmonton, AB Canada
    I know the feeling...One of my belts squeaks on initial start up & acceleration, but only until the engine warms up & then it stops! LOL
    Dec 2003
    Austin, Texas
    http://www.hondaautomotiveparts.com
    just get it from them man. unless you wanna use just regular washers. i should be getting mine in today or tomarow, ill give you a width on it when i get it.
    Car Pics
    vBGarage
  1. Squeaky Clean
    By Nate2310 in forum Classic Honda Pics & Videos
    Last Post: 12-05-2004, 09:55 AM
  2. Squeaky to the max
    By Accordie in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-06-2003, 08:52 PM
  3. Squeaky Squeaky
    By rideredorgohome in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-18-2003, 06:33 PM
  4. squeaky belts
    By GDGuy11B in forum Classic Honda Community Chat
    Last Post: 11-17-2002, 05:47 AM
  5. Squeaky Brakes
    By enkeisroller in forum 3geez Accords
    Last Post: 11-13-2002, 04:00 PM
