How do you get the Rear bumper off ?
89' Honda Accord LX-i with Se-i Interior
look at the manual, or crawl under the car, and find the bolts holding i on............
take the tail lights off and you would be able to see the blots
If the rear doesn't slide out you need to remove the 3 screws holding the sides of the bumper to each fender well.
Under the car there should be four 14 mm bolt I believe that hold the metal bumper frame to the car... https://www.3geez.com/showthread.php?t=32727
The pics show the braces for the rear metal bumper but the bumper part was cut off... it's now held there by only one bolt instead of two so I could stick the braces out further. But anyways you should get some idea of where the bolts are located
I have a pic of the rear metal bumper removed...
If you want to remove the plastic bumper shell you can unscrew it from the metal one.
I have a 2 door so it diffrent and i got it off now
