I desperatley need a battery wiring diagram or a how-to on where the negative line goes from the battery on a 88 accord.I also need the diagram or how-to make the entire dashboard wiring or where to order a kit for the spiderweb/harnesses,or if i should just buy another accord with wires that arent fried,exposed and touching eachother causing headlight fluctuations and dash gauges start dimming in and out.I replaced the battery and the negative was never attached to anything but the frame before i got the car.At least it starts now and is a little brighter at night,lol.Im also having carb adjustment probs and I hear a ticking like a diesel chugging,also my pedal or throttle line is getting hung up a little on something causing idle at 1500rpms,allthough i can pull on the pedal from the inside of the car and get the idle back down.Any help will be greatly appreciated.
