Ok guys here's what i had done to install my amp and my sub.
I ran the wire from the battery through the left side of the car.
Ran the cables from the HU from the right side of the car. Both the RCA and the REM cable are running together don't know if that is the problem. Well in the beginning everything worked fine till i tore up my box, Then i changed my box and it was all fun but not for long. The sub stopped working, I don't know if it is the sub or the amp which is creating the problem well what was happeneing was that the sub would work sometimes and it won't work sometimes. like there was a loose connection or someting. So i thot my preamps would be the problem so i switch the RCA cables from the rear preamp outputs to the front preamp outputs on the HU. Then it worked fine for a couple of weeks and now it is doing the same thing. when i am driving i feel the bass one second and the next second it is gone. If I push the break I feel the bass and if i press the gas the bass is gone, same as what it was doing earlier. it is really weirdI don't know what to do and i don't know what i am doing wrong. Is it the wiring somewhere. I don't have my amp or the sub mounted. so would that be a problem. also i wasn't getting this problem with my old amp, its the new one which is irritating me. If you want to know the spcifications of my amp and the sub they are here: https://www.3geez.com/showthread.php?t=38553
Please help me guyz... Its really pissing me off now...
Thanx
-Imran
