Results 1 to 5 of 5
Thread: automatic to 5-speed: How the hell do I make my reverse lights turn on???
    Exclamation automatic to 5-speed: How the hell do I make my reverse lights turn on???
    OK, I took the console apart, according to the shop manual when the auto is in reverse there is continuity between the green/red wire and ground... well I did that (shoreted the Gr/Rd wire to the chassis) and they won't come on (yes the key was in the "ON" position, the fuse is fine)
    am I doing somehting wrong or do I have an electrical problem? They were working fine b4 the swap
    May 2003
    88 Accord LX 88 Accord LXi
    The green/red wire to ground will only light up the R in the dash to tell you that you are in reverse. You need to connect the green/black to the yellow wire to make the back up lights come on.
    gangster it works! this needs to be in the how-to (or maybe it is I think I'm part dislexic lol) I'm going to try it without the green/red. I was afraid to do the yellow-green/black short b/c it said it was the "inhibiter" circuit but when I tried it the car still started
    thxs again
    May 2003
    There should't be a need for the green/red to ground. You should be fine without it.
    10/Honda/Ridgeline
    NJ
    HOpe this Helps you Erick. You are the 3rd person who has had this problem. I had it too, but it was because i did not have the 5spd engine bay harness that had the clips for the tranny switch. But i followed the following schematic to rig up my own from my reverse switch on the tranny to the engine bay harness so it would work and it worked fine.
    click the pic to enlarge
  1. Issues with gauges and turn signals/reverse lights
    By ventureforth in forum 3geez Accords
    Last Post: 01-22-2013, 03:36 PM
  2. Replies: 29
    Last Post: 07-16-2012, 01:29 PM
  3. Automatic stuck in reverse...Engine racing...???
    By hansenmick in forum 3geez Accords
    Last Post: 01-11-2010, 09:46 PM
  4. any way to make the bumper signals turn on when lights are on?
    By frantik in forum Classic Honda Community Chat
    Last Post: 01-10-2007, 08:31 PM
  5. Do reverse-glows make your gauges stick?
    Last Post: 07-18-2003, 09:20 PM
