Results 1 to 2 of 2
Thread: Nominations for AOM - January 05
    87accordlxi's Avatar
    Oct 2000
    It's that time again. Nominate your favorite 3geez ride!
    Check out the Rules & Regulations
    All winners in the past year are ineligable for nomination:
    March 04 - OldSchoolSwap
    April 04 - Bloodlust
    May 04 - BITESIZE
    June 04 - 88lxi68
    July 04 - RobT5580
    August 04 - Justin86
    September 04 - carotman
    October 04 - Vinny
    November 04 - Paul Aerodeck86
    December 04 - Mike's89AccordLX
    Duplicate nominations will be deleted
    Posts made that are not nominations will be deleted
    Invalid nominations will be deleted
    - Joe
    LXi User buds302's Avatar
    Jun 2004
    90 civic hb R.I.P. , 2002 EBP EM2<<figure it out..its not that hard
    new castle pa
    ok this is the first time im doin this i hope it turns out.
    i nominate a20a1 for the second month in a row.
    hes given me alot of advice and i think its his turn
    SUSPENSION MODS:
    - ACE 15" CYCLONES (YES 15's... I'll only go larger to get larger brakes... but I'm not in the market for either, 15's is well suited for all round racing, no bling bling here bubbies.)
    - DUNLOP SP Sport Tires
    - MAXSPEED 90-97 CO's
    ENGINE MODS:
    COLT CAMS 280/288 Regrind
    - Lubed by VR1 20w-50
    -- Filtered by K&N GOLD
    --- Increased Oil PSI
    ---- Mildly Strict 4000-7500rpm powerband
    ----- Pulling a lowsy 8-10" vacuum max @ 1000rpm Idle
    High duration/overlap frickin blows
    but shooting flames out the carb when you get a reversion pulse is badass
    2 B&M Trans oil coolers
    - Running on TRICK SHIFT & MOBIL 1 ATF
    WEBER DGV (CARB IS TOO SMALL)
    - Running on 89 Octane
    -- Filtered by FRAM
    --- Still not jetted right
    ---- Made a 1" carb spacer for Carb
    CUSTOM 4-1 CIRCLE TRACK HEADER
    - Mild Steel
    -- 3" Collector
    --- Coated with ceramic paint
    ---- Currently fitted with a 2" Muffler for daily driving
    BOSCH Platinum +4's
    ACCEL SUPER COIL
    ACCEL CUSTOM WIRE SET
    OTHER MODS:
    CUSTOM HOOD SCOOP
    JDM TAIL LIGHTS
    ROUND TAIL LIGHTS
    RELOCATED BATTERY TO FIREWALL
    INTERIOR MODS:
    MOSTLY STRIPPED INTERIOR
    CUSTOM DASH W/ ONE MOUNTED AUTOMETER 8K RPM TACH GAUGE
    IN THE WORKS
    - 390 CFM 4BBL or 500 CFM 4BBL
    - CUSTOM 4BBL DIVIDED PLENUM INTAKE MANIFOLD
    - UPGRADED FUEL PUMP ( CARTER SUPER STREET PUMP )
    - FUEL REGULATOR
    WISHFUL THINKING
    - 16 GALLON FUEL CELL
    - HIGHER COMP PISTONS
    - BALANCED CRANK / KNIFE EDGED
    - VARIOUS HEAD WORK AND INTERNALS
    b u n n y · t y p e R
    "the bunny liked the go-faster stripes... but wasn't too keen on the rear spoiler and ridiculous bodykit"
  1. Accord of the Month Nominations - January 2009
    Last Post: 12-15-2008, 06:45 PM
  2. Accord of the Month Nominations - January 2008
    Last Post: 12-12-2007, 05:57 AM
  3. Nominations for January 2007 Accord of the Month
    Last Post: 12-07-2006, 02:39 AM
  4. Accord of the Month nominations: January '06
    By NXRacer in forum Accord of the Month Archives
    Last Post: 12-13-2005, 08:50 PM
