I took my 1987 Accord LXi in last Tuesday for inspection, and it failed emissions with the following results:
Standard Current Reading Result
HC(ppm) 220 327 FAIL
CO(%) 1.2 5.06 FAIL
CO2(%) 11.4
Engine RPM at reading: 985
Ok, so then I wet out this past weekend and put on a new set of plugs, plug wires and I adjusted the idling. I also put in two cans of 104 racing formula octane booster and the CRC G2P oxygenator on a full tank. I ran the car until it was 1/4 tank full, warmed it up good and took it in for inspection again today. Here are the new results:
HC(ppm) 220 1279 FAIL
CO(%) 1.2 6.19 FAIL
CO2(%) 9.9
Engine RPM at reading: 1042
Ok, so now what parts should I change out? Oxygen sensor? EGR valve? What should I check next?
