Results 1 to 7 of 7
Thread: Drive train casing problem
    DX User NashvilleLX-i's Avatar
    Aug 2004
    1989/Honda/Accord LX-i Hatchback
    McMinnville, OR
    ok i took my tranny out and while cleaning it i found several cracks on the inside near the drive train i was wondering what i have to do about this do i need a new transmission? or will it work fine it worked fine before so i dunno please help
    89 Lx-i hatchback bought for only $750
    Feb 2004
    89 accord lxi
    down by the bay
    if the cracks are not severe and aren't causing leaks you should be ok. it is very common for our transmissions to have small hairline cracks in the casing around the differential and shift rod area.
    Nov 2002
    Ridin Dirty in New York
    are you sure they are even cracks... most times its just casting flash. Unless you can see somthing leaking through it or its gonna break or somthing... leave it alone
    Aug 2004
    McMinnville, OR
    ok cool thanks guys i was afraid i need a new tranny
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    well my trans cracked and look what happend..... it ok tho, i LOVE my si tranny
    I havent forgotten my roots
    Aug 2004
    McMinnville, OR
    yeah i looked closer at it and it is probably casting flash sorry never seen anything like this well you live and learn and dont make the same mistake again.
    Nov 2002
    if in doubt... grind it down and see what it looks like... carefully.
  1. Transmission Casing Leak
    By Andy in forum 3geez Accords
    Last Post: 07-03-2010, 07:58 PM
  2. Headlight Casing
    By 3rd Party in forum 3geez Accords
    Last Post: 02-26-2009, 01:51 AM
  3. Help With Valve Train Info
    By mcfly in forum Restoration & Custom Fabrication
    Last Post: 05-06-2007, 09:16 PM
  4. Over reving: valve train damage?
    By HondaBoy in forum 3geez Accords
    Last Post: 05-05-2007, 02:49 PM
  5. Valve Train Performance
    By 88fasthatch in forum Performance
    Last Post: 06-20-2003, 04:02 PM
