Results 1 to 11 of 11
Thread: auto-manual conversion w/ ONLY lude parts?
    ok, heres the deal, i have access to an 85 prelude 1.8 dual carb, and i was wonder if i can use the pedal assem./clutch cable, accel. cable FROM THE LUDE on my 87 accord hatchback?
    please get back to me asap, because the second gear on my 'cord is out and i need to do something fast.
    thank you.
    PhydeauX's Avatar
    Eastern Penna
    No, You also can't use the trans unless you swap the diff.
    andy
    from what i have heard from everyone else i wont need to swap the differential......i just need one accord axle, and one lude axle.......my main concern is whether or not the pedal assy. and clutch and accelerator cables will work....
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    you could just try pull the pedal assembly out and try and compare it. it's prolly different though.
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Pedal assembles, and shift rods are different. The rear mount is the same.
    '88 LX-i Coupe --- LS/Vtec
    too different to use?
    could i re-drill the lude pedal assy maybe?
    grrr......may have to fix the stupid ass acclaim for the winter....my truck will never make it
    PhydeauX's Avatar
    Eastern Penna
    Quote Originally Posted by Hoppin Hatchie
    I'm not sure where you heard that but its wrong. The accord axles have a larger diameter then the 1.8 prelude axles. You won't be able to stick an accord axle into the trans, and the prelude axle will spin freely in the accord hub. To make it work you would need to swap the entire front hub, carrier, breakes, etc from the 1.8 lude onto your accord if that is even possible and use the prelude axles. (I'm not sure anyone has ever done that but its a reverse of the process 1.8 lude owners have to go through with a 2.0 swap).
    andy
    damn...that sucks ass..... how hard is it to swap a differential? never done it on a fwd...
    PhydeauX's Avatar
    Eastern Penna
    If you have a haynes manual it goes through the procedure. It's not that hard if you follow the instructions. Unfortunately on a fwd tranny you have to take the whole case apart. You are also most likely going to need a 5 speed accord diff. I have no idea if the diff from the auto trans will work, but my first guess would be it won't.
    andy
    carotman's Avatar
    Montreal South Shore
    Or...... just use Prelude inner CV joints on an Accors axle. Easier than swapping the differentials I think. (at least for me)
    I need these parts!
    how would i go about swapping the lude cv's onto the cord halfshafts?
    it looks like there connected to the halfshafts pretty well.....
  1. Doing Auto-Manual Conversion soon.
    By DDRaptor in forum 3geez Accords
    Last Post: 11-09-2006, 05:05 PM
  2. Doing Auto-Manual Conversion soon.
    By DDRaptor in forum Carburetor Tech
    Last Post: 11-03-2006, 04:25 PM
  3. FS: Auto & manual tranny and associated parts
    By mykwikcoupe in forum Trading Post
    Last Post: 01-17-2004, 11:51 PM
  4. Replies: 6
    Last Post: 08-04-2003, 08:17 AM
  5. auto to lude manual tranny swap
    By maka_RTH in forum 3geez Accords
    Last Post: 12-02-2002, 09:27 AM
