Hello! ;]
Just came back from Florida vacation about 4 days ago, flew, left my car here in Illinois, sister drove it--and i've driven it a couple times since i've been back and started experiencing problems with it just yesterday.
It's got about 170,000 miles on it. When it's cold it takes about 5 seconds to actually start--When I start out driving it idles high (which is common from what I understand). Yesterday, I started it, and it started with the usual 5 second delay. When I got to my destination I noticed steam coming out from the hood, late, I didn't check under the hood--14 hours later I got back in it and started it up and it took a little longer than 5 seconds to start, then it sounded as if the belts were squealing, and it was making a rough loud rumble noise, so I turned it off and started it back up a minute later and it started up as usual. On the drive home I noticed the tempterature gage showed that it was getting hot, but I was only a couple minutes from home so I made the drive--When I got home, same steam coming out from under the hood, and it was making like a boiling/hissing sound. I pulled the car in the garage and took a look at it, the steam was coming from the radiator, and it looks as though there's a leak somewhere because I could see drops of water around, although I haven't seen anything that's actually leaked out when I look UNDER the car. I also noticed the fans weren't turning on. Any ideas? I can't take it have it looked at for another 2 days on account of work, thought i'd get some insight on here to see if I could get a brief idea of what the problem MIGHT be.
Thank you for your time!
-Eryn
