Results 1 to 10 of 10
Thread: for the "purists"
    Vanilla Sky's Avatar
    1999 Penalty Box
    for the "purists"
    here's a set of drivers for the rear deck in your car... it's a 6x9 woofer, nothing more... this helps preserve a good soundstage while providing rear fill and an extra oomph...
    http://www.partsexpress.com/pe/showd...number=264-836
    not at all a bad price, either...
    new, these are no replacement for a full-blown subwoofer, but if you want to stay light and still sound great, something like this is PERFECT...
    Moodybluesr's Avatar
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    Tang Band sells component parts for home speakers... note the 8 ohm impedance. Not that this is an unworkable point (very easy to make a single 4 ohm load obviously) but I doubt that those woofers are meant to handle the environmental extremes found in a car. That and the frame on that woofer looks a little big to fit in our 6x9 pod; you would have to get creative with a dremel if you wanted to mount these in the deck.
    The Boston RM9s that I have in the back of my car are similar to these anyway. They use a 6x9 inch woofer with a component tweeter suspended above so as not to break the structural rigidity of the woofer cone. If you don't want the highs from the back end, it is pretty easy to take them out with a crossover (which you would have to use with the Tang woofers anyway) but the Boston's do cost quite a bit more (assuming you can still find them... OOP).
    1999 Penalty Box
    exactly... you can't find 6x9 woofers much anymore... not even used on ebay...
    the 8 ohm impedance is a non-issue... it's not like your amp will have a problem driving the 8 ohm load... and of course you can fo mono and come out iwht a 4 ohm load as you stated...
    also, for someone wanting to run larger speakers, cutting the basket is also a non-issue, as most of us here have modified our baskets...
    i posted these because i was having a horrible time finding a set of 6x9 woofers that didn't cost $300 a set... these are just a less expensive alternative to the much more expensive auto sound drivers that are on the market now...
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I have an Audiobahn 6x9 in the center of my lude and man does that sound nice. It's got the chrome basket and everything. I also just bought some Audiobahn 25mm tweeters for in the center of my dash. 4 tweeters and 2 speakers in the front, 2 speakers and 1 6x9 in the rear, 2 12" subs and 2 good amps, and 1 big capacitor = 1 happy mikey
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    where you putting the tweeters at in the front?
    Mankato, Minnesota
    The usdm ludes had 2 dash tweeter pods r and l. The jdm ludes had those and a tweeter pod in the center of the dash also . I got my hands on the jdm speaker pods I have the one for the front tweeters and the center 6x9.
    SEi User danronian's Avatar
    Boyertown, PA
    But the problem even with modifying the basket is that real deep speakers often get close to hitting the rods that keep the trunk lid open, but then again you can always modify anything to make anything fit. For my rear fill sound I use two cheap 3-way roadmaster 6X9s in enclosures mounted standing up from the floor of the trunk. To keep them only producing low frequencies I just make it so the rear of the car only is sent lower frequencies with my HU. Since I put those speakers in the boxes they really don't distort at all with bass, they have a higher pitched bass then when they were just in the rear deck but I think they sound alot better in the boxes. True they are low quality speakers but I find them fine being only powered by my Pioneer HU.
    Feb 2004
    89 accord lxi
    down by the bay
    Quote Originally Posted by danronian
    hooray for the pioneer f.i.e.! that's kind of like the setup i have in my beater. $12 7" goldwoods from parts express in the rear deck running everything below 150hz.
    1999 Penalty Box
    i don't use the FIE on my deck... i have a set of infinity midbasses in the back deck, and a simple inline 6dB/octave crossover attached... i think it's set up at 1700Hz... i'd like to have it set up a bit lower with a 12dB/octave crossover, but the speakers just aren't worth it anymore (one has a repaired cone and surround)...
    BTW, i'm looking at probably the same goldwoods for use in my car... i'll use them all around, along with a dome mid and dome tweeter up front... custom crossovers throughout...
    2006 Nissan 350z
    Does school count?
    Thanks for the site!
    These cheap badboys are exactly what I had in mind for a project:
    http://www.partsexpress.com/pe/showd...number=290-025
    natsugusa ya
    tsuwamono domo ga
    yume no ato
  1. Classic "Taxi". Good ole Jim. "What does the yellow light mean?".
    By Bluntman in forum Classic Honda Community Chat
    Last Post: 06-28-2012, 12:21 PM
  2. "vacum situation sucks" NEED HELP! "Please"
    By wayne59 in forum 3geez Accords
    Last Post: 07-22-2009, 11:41 AM
  3. Those "diamond cut" little blue "city lights"
    By plasmadis in forum Interior & Exterior Care
    Last Post: 02-01-2006, 01:13 PM
  4. Replies: 10
    Last Post: 12-28-2002, 09:24 PM
