Results 1 to 14 of 14
Thread: Holy mother of crap
    k-roy's Avatar
    87 LX
    Holy mother of crap
    2.0l honda b18 crate engine long block
    From the belly of the high performance giant Mr.Gasket, emerges a milestone in sport compact technology appropriately named "The Beast." Born from a coalition of racing engine experience so strong that its performance and reliability are truly indisputable. Built from the finest hand-picked components in the world, every part is brand spankin new, right down to the last oil pan bolt. So confident are we in this Beast's abilities, we also back it with a 12 month or 12 thousand mile warranty. The BEAST Specs Bore:84mm Stroke:89mm Rod Length:140.8mm R/S Ratio:1.58:1 Compression Ratio:11:5:1 Intake Valve Size:34mm Exhaust Valve Size:28mm BHP:270@7800 RPM (this is an engine dyno figure) Peak Torque:185 ft-lbs@6000 RPM Camshaft Spec:Lift/Duration: IN. 0.485,252,EX. 0.466,262 Cam Gears:Unorthodox Racing (Ultra T) ARP: Head Studs, ARP Rod Bolts Baffled Performance Oil Pan Fuel:Quality 92 or higher octane (pump gas) Must use modified or aftermarket ECU. Engine is cold tested from the factory, for cylinder leak down, proper oil pressure, coolant and oil leaks. Complete with new factory oil pump, water pump, timing belt and covers, hardware, and VTEC solenoids. Timing is factory set. Assembled with precision at Performance Assembly Solutions. Engine has produced 13.4 second E/T's in a 2600lb car, and still achieves 30mpg. Wiseco forged pistons. Oliver E4340 Chrome Moly Rods. Eagle Forged 4340 crankshaft. Mr.Gasket MLS head gasket. Also available in a short block version.
    Model Number: GX20
    $12,000
    Damn I need a second job and a good banker.
    Nov 2002
    Ridin Dirty in New York
    or you could throw a k24 head on a k20 shortblock and run 12s for much less... Very nice, but for mr gasket... little too late
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    yeah i read about that in sport compact, then i went to the bathroom for 30 min :S
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    For $12,000 that better include install. No one in there right mind will fricken spend $12,000 and want to go 13.4 seconds in the 1/4 mile. Throw a turbo on there and be a 10 second motor but that will be another 4 to 5k since you have a higher compression motor you want to tune that thing right so you wont blow it.
    It's definately a good idea and step for performance companies but I think 12k is a bit much considering those domestic crate motors for like 2 to 3k making over 350 hp. I think they need to start figuring out that they need to be somewhat comparable to domestic stuff or they won't get any business.
    Our cars can easily run 15's so lets spend $12,000 and probably $4000 more for ecu and install so we can run mid 13's !!!!! That sounds like a great plan hahahahha
    SEi User od2681's Avatar
    Nov 2002
    2003 Infiniti G35 sedan
    Houston Tx
    damn....thats a lot..
    but that would be one sweet soundin engine....
    Nov 2002
    it must be sleeved...
    wow, I wish, but for less you can buy a 502 crate Chevy with 850 HP and an Elcamino to drop it into for the difference!
    Eric
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Doesn't DART make engines too?
    Anywho thats cool.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    i better be getting 10 seconds for 12 g's. i wonder if thats the real price or MSRP.
    Nothin' 2 Old Racing
    that's real nice, but the price is a real bitch with a capital B. you can build one up with machine work included for cheaper, duh. but i guess if you want it easy you best be ready to pay that then huh. i still want the 2.0 engine. B20 prefurably. i would like to see someone who has bought this engine though. i cant see paying that much for that engine. especially if it doesnt come with a tranny.
    k-roy's Avatar
    87 LX
    Whew its been a while but oh well
    AccordEpicenter, no offense but its not a fair comparison. This one is much more stout, more HP and a hell of a lot more durable. No resleeve job here, its a $2500 completely new aftermarket block. Yes $12,000 is MSRP witch is not quite the retail $. Its a brand spanking new product. I walked into the jegs store the other day and one was sitting on the counter (I actually got a hard on). The guys there would not tell me the price since this was a special order and they will not be stocking them in their warehouse. Mike, you can't match this durability and warrenty with used parts, this one is 100% new, and you gotta get it in yourself. Engine swaps are no fun, but this is much easier than say a H or F (Witch I just did) into a Civic. Bs are much easier to work with since they are small. That was also 13s in a 2,600 LB car w/o nitrous or boost, witch this is made to handle. The salesman told me that there is also going to be a low compression version with differant cams for turbo/supercharging. OD, I need to find the punk kid that baught that engine (a fuckin 16 year old) just to see it live. A20A1, Dart is known for v8 heads and nascar/drag racing, they make this block 100% new.
    My take.
    yea its expensive, but its the crem de la crem. Here is my rough estimate on a lot of the parts. Block $2,500, Crank/Pistons/Rods $2000, head $3000. Thats $7 grand for the big ticket parts. Probably another grand and a half in other stuff like the oil and water pumps, timing components, covers, oil system and pan, bearings, rings, studs, etc... so $8500 in parts, $1,500 in labor. Thats if you want to buil it yourself. So it doesn't seem like so bad of a deal. plus its perfect for boost.
    I know my B18 project will never reach these numbers without boost, but I should be able to creep into S2000 range.
    Oh and a 502 Camino would walk over 95% of all race Hondas, but not in the turns. Its all in ones opinion really, a badass car is a badass car no matter what it is.
    LXi User MarioBurke's Avatar
    Feb 2003
    Gun Metal 88 accord Fi Swap
    Sacramento, California
    Quote Originally Posted by k-roy
    **please side note for the two of you that always read my post and go talk shit about it, get a life**
    Feb 2004
    89 accord lxi
    down by the bay
    DART makes a b18/b20 short block, aluminum with a closed deck.
    DX User HKSdrift3r's Avatar
    Jun 2004
    93 240sx F/B
    Dart also makes new ported and polished heads for the b series.. the block and the heads are expensive as ish!
    " I love money, it'll probably be the death of me." ~ Lloyd Banks
  1. Holy crap!
    By Angelois in forum Classic Honda Community Chat
    Last Post: 03-25-2012, 10:38 PM
  2. holy crap whos car is this?
    Last Post: 08-14-2008, 05:08 PM
  3. holy crap
    By lostforawhile in forum Carburetor Tech
    Last Post: 05-07-2006, 10:45 AM
  4. Gas Mileage!! Holy Crap!
    By whyterice in forum Classic Honda Community Chat
    Last Post: 05-17-2004, 02:41 PM
  5. HOLY CRAP (Pics)
    By locknload68 in forum Classic Honda Community Chat
    Last Post: 05-14-2002, 12:36 PM
