Anyone here know at what rpm the rev limiter kicks in?
If my tach is correct I hit mine around 6750-7000 rpm. (Its kind of hard to tell exactly)
Are the specs to the rev limiter listed somewhere? Its kind of hard finding info on it.
reb limiter, i don't think they have on our cars.
i think at 6750 or 7000 our cars maxed out.
carb fuel pumps are supposed to cut at 6500 rpms
Eric
My cars nowhere being maxed out at that rpm. I can't go any further cause I keep hitting the damn limiter. I just want to know if someone knows for sure where the rev limiter is set.
Oh and my car is efi.
do u have an automatic or 5 speed?
later !
You should hear a lot of ticking coming from the engine when you redlind.
Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
B-Day: 07/87 in Alliston, ON Canada
The best mods are mods that can be modded over and over again.
My car has one, and it was real easy to find when my car still have it's crappy little 13" tires cause it was way to easy to break traction. I'd hit it around 6500rpm's to 6700rpm's.
Now I d
Do you agree the needle was well in the red when it hit the limiter?
Anyone else hit their limiter and remember where abouts the rpm was?
