Results 1 to 5 of 5
Thread: changing o ring, need help
    88 LX Action
    Podunk, Alabama
    i got the distributor cap and rotor off, but cant loosen any of the other screws inside, or get the square wiring box off the top, ill probably get it eventually but does anyone have any advice? these screws aren't easy.
    also my air filter and carbureator started smoking(smelled like gas), and the engine wasn't even on. i think this might be since i had to turn the engine over to position the rotor in line with the first spark plug place, and the gas didn't burn, but just want to make sure. thanksss
    real 3geez http://www.3g-generation.com
    i sold the honda. now working on a car with little bit more potential, an 88 supra. i still stop by occasionally.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    run that by me again... what did you do to the distributor and why did yuou rotate it to #1.
    by the square box to you mean the igniter?
    and I wouldn't suggest rotating the crank while the spark plugs are installed.
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    If you are trying to change the distributor o-ring, you just have to remove the two bolts holding the distributor to the head, then pull. The o-ring is easily replaced. Just make sure to make a fine mark across the front of the distributor where it meets the head so you can put it back later without having to set your timing.
    88 LX Action
    Podunk, Alabama
    i got it, i was trying to take off the wrong thing, all good now.
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    You mean the reluctor?
    That ninja star looking peace that's black and has a pin in it?
    Those are expense to replace. I don't think they go out that badly to be replaced. I would just leave it.
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
  1. FS: NEW Kay Eng. Ring ($349.00 or trade)
    By 89NinjaAccordLX in forum For Sale
    Last Post: 08-26-2009, 02:37 PM
  2. Distributer O Ring
    By Cody in forum 3geez Accords
    Last Post: 01-25-2009, 02:42 PM
  3. distributor o-ring ?
    By Cant Stop in forum 3geez Accords
    Last Post: 04-30-2006, 11:45 AM
  4. Distributor O-ring
    By LyFeWoRx in forum 3geez Accords
    Last Post: 06-13-2003, 09:13 AM
  5. Distributer O ring???
    By mrmojorisin in forum 3geez Accords
    Last Post: 09-18-2002, 04:44 AM
