1. The transmission - When I'm in Park it idles at 2500RPM. Then I put it into Reverse and the car jerks a little back and the RPM drops to 1200. Then I put it into Neutral and there is no jerk but the RPM goes back up to 2500. Then I put it into Drive D4 and the car jerks immensely forward as though it had just been rear ended and the RPM goes up to 1800ish. My question is why does it jerk like that and how can I fix it?
2. Minor problem -- When I'm driving at speeds of 10mph or more there is an annoying squeaking sound coming from the driver's door. It sounds like it's coming from the where the bottome of the window and the door panel meet. How do I fix this?
3. Minor problem -- When I start the car at night (about 60ºF) there is a loud squeaking noise from under the hood, probably a belt. It's very piercing and annoying, but once the car warms up and I tap the gas, the squeaking stops. Any advice?
4. My CV joint boots cracked a while back and there is dirt in the CV joints. It does make a cranking noise when I turn. I have learned to live with this but should I rush out to have this fixed? How do I know when it's time is up? How long can I go before I need to have it fixed?
Thx for the help...
