ok i have a leak in that powerstearing loop in front of my radiator i was wondering if i could just replace it with one of those remote tranny coolers they sell.... would this be better? or would it work at all? thanks.
ForSale!
88Accord LX AUTO
NEEDS:
Transmission
Tires
Altinator
Belts
Battery
PERFECT Maroon Interior
Call or Contact Dan @ 1-617-893-8320 or E-mail at [email protected]
I removed the whole deal with my p/s. and there is definatly enough space cleared up too add a tranny cooler.
are you gonna bypass the one in your radiator, or just add to the mix?
The loop you have on there now is less restrictive. If you use a tranny cooler your PS pump will have to do more work to run the fluid through all those smaller passages the system. A tranny cooler is more than you need. You should be able to find a loop that doesn't leak for cheap at a scrapyard. A lot of people have taken off their PS, but parking is a real bitch like that so I decided to fix mine.
Mike
If you bought a tube and fin design then it's like the loop but there are more of them... it's not made by B&M.... cause the B&M one are different. On the tube and fin one you can see metal pipe waving up and down and you can see the tiny metal fins like your radiator has.
and what would htis do A20???
ForSale!
88Accord LX AUTO
NEEDS:
Transmission
Tires
Altinator
Belts
Battery
