Results 1 to 3 of 3
Thread: Bucking at part throttle. What's the fix?
    My '89 LX auto is bucking at light throttle. I've read a few posts on this and it seems to be a common problem. Has anyone had any luck in solving this problem? Any tips/tricks/advice you can give will be very helpful. It doesn't feel like a transmission problem, but I could be wrong. I've done a full tuneup with the exception of distributor cap and rotor (which will be done soon). Thanks in advance for your help.
    '89 LX auto
    Other cars:
    2001 Nissan Maxima SE (Anniversary Edition)
    2001 Chevy Tahoe
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Have a look at this thread, check your booster venturies...
    https://www.3geez.com/showthread.php?t=8972
    Feb 2004
    88 Accord EX 4dr automatic
    Nova Scotia, Canada
    Make sure it isn't carb-ice if you live in a cold climate. If not then it sounds like a problem I had with mine. I had to run a power line from fuse box to that solinoid thing at back of carb. It would sputter at the RPM range you speak of when fully warmed-up. Worked fine when cold and under 3/4 to full throttle when warm. It took me a month to figure it out. That solenoid closes when key is turned off and/or when coasting above 20 mph when working properly. I had to hook a multy-meter to see it act up and narrow it down to the line to that carb solenoid. It's supose to be controlled by that computor under drivers seat. I just wired it with a quick-connect, fused line and on an accessary male connector on fuse box that is only energized when key is in the on position. Apparently there is some relay under drivers seat but I didn't bother with it I just hooked it up direct to fuse box as stated above. Replacing relay may be easier. I wasn't aware of it when I fixed mine. Check for pics of that carb solinoid on this 3 geez site. There are pics in there somewhere. Good luck, Mike
  1. lean idle and part throttle
    By detroit series 149 in forum Carburetor Tech
    Last Post: 09-03-2009, 12:41 PM
  2. bucking in second gear
    By fijisac in forum Carburetor Tech
    Last Post: 07-26-2009, 09:19 PM
  3. Bucking when release gas pedal
    By bushbean in forum 3geez Accords
    Last Post: 09-22-2006, 07:37 PM
  4. please help ASAP my car is bucking
    By goldadition in forum 3geez Accords
    Last Post: 07-30-2003, 02:37 PM
  5. '87 lxi stumbling bucking stalling
    By Pyre in forum 3geez Accords
    Last Post: 06-03-2002, 11:28 AM
