Results 1 to 10 of 10
Thread: Catalytic Converter
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    Catalytic Converter
    i had already done a search but no answer's to my question.
    when i start my car it rattles around in the front area...
    only when it's cold.
    then sometimes it buzzes too.
    i put her on a lift and hit the cat and it was making rattling sound like a bunch of rocks..
    plus i noticed that when i step on the gas it'll bog down and then take off..
    it's worse when the temp is in a certain "normal" range..
    but once it fully warms up it'll bog a little.
    plus so far when i step on the gas she'll cut off.
    so now for the newb question....
    is this the sign of a clogged cat???
    ****** 1994 nissan maxima SE ******
    May 2003
    88 Accord LX 88 Accord LXi
    Sounds like it could be the cat. I think there should be about 100 degree temperature difference from the front to the back of the cat. Once they break down internally they do rattle. And if it gets clogged enough you will lose power. Most repair shops should be able to check it quick and easy.
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    sure sounds like a clogged cat to me ...
    Jay
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Sounds like a bad cat to me me. Put you in a resonator if your local emission laws permit.
    chicago , il.
    to self : that bitch.
    well to be honest i'm not surprised nor pissed.
    why..
    well i should've known from the get-go when the previous owner told me that he TRIED to do a tune-up (yea right)......
    so in addition to upgrading my exhuast and getting a new cat...
    i might as well get a 88-89 exhaust manafold..right??
    chicago , il.
    ain't this a bitch....i just recived a emission card through the mail....
    chicago , il.
    okay..another newb question.
    ummm how bad is this hurting my engine.
    i know it shut's off because of the cat...so that's why i'm asking how bad is this hurting the engine...
    if it comes down to it i might have to punch a little hole in the exhuast to help it till i can get the money to fix the problem.
    Quote Originally Posted by accordlxi2.0
    Prolly not the best thing for it. Dunno how long you can run it really.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    It kills your gas milage more than anything. I would take the cat off and clear it out before I would put a hole in the pipe ahead of it. You will not pass an emissions test but you won't now anyway.
    chicago , il.
    well...won't it sound loud???
    plus the pipeing is screwed up...
    one side is like 1.3/4 and the other side is like 2 inches and then it goes back down to 1.3/4...
  1. Catalytic Converter
    By BoogerBurns in forum EFI Tech
    Last Post: 10-11-2009, 07:45 PM
  2. Catalytic Converter
    By ELM'sLX+CHL'sDX in forum 3geez Accords
    Last Post: 12-20-2004, 06:31 AM
  3. Catalytic Converter
    By slowazz86carb in forum Performance
    Last Post: 07-24-2004, 11:08 PM
  4. best Catalytic Converter
    By aCCo[R]D in forum Performance
    Last Post: 04-30-2004, 08:49 AM
  5. catalytic converter ?'s
    By Mystic1 in forum Performance
    Last Post: 12-12-2003, 05:17 AM
