Results 1 to 25 of 39
Thread: Early morning hell
    LXi User DanLXI88's Avatar
    Mar 2004
    1988 Honda Accord LXI, 90 Caddie 90 Chevy
    Columbus, Ohio
    Early morning hell
    I have an intermitting problem in the mornings. Last couple of days my 88 LXI has been missing really badly when cold and large amounts of raw gas smelling smoke comes from the tail pipe. After it warms up the smoke stops and the idle smoothes out. ANY IDEAS?
    **Some Info on my car can be found here **
    http://www.cardomain.com/memberpage/547146
    86LXItooFAST4me's Avatar
    Austin, Texas
    when was your last tune up?
    Car Pics
    vBGarage
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    The missing could be due to moisture in the dizzy. Check to see if the cap is cracked anywhere.
    Mar 2004
    Columbus, Ohio
    Tune up has been awhile honestly maybe 4 years at least. But this thing set for a very long time. I have been wanting to do the tune up to it but have not had time. Could this be the problem? Some days are worse then others.
    Austin, Texas
    tune up involves the cap and rotor and all the ignition head aches. so possibly. couldnt hurt if its been 4 years anyway.
    just do the cap and rotor and see if that helps.
    Car Pics
    vBGarage
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    cap, rotor, spark plugs and wires. oil change
    DX User AD9SloAccrd's Avatar
    May 2003
    89 accord lx
    Bowling Green, OH
    my car did that last year. it kept getting worse and worse and it ended up that i had to get a tune-up and timing belt... all that fun stuff.
    chicago , il.
    damn man, 4 years and i thought a year was bad.
    that's your problem..but it's deffenatly the cap and rotor.
    the sparkplugs just help the problem worsen more.
    yeah... does it throw a check engine light?
    Mar 2004
    Columbus, Ohio
    Nope, no check engine light or codes from the computer. The Oil change I have done regularly. The timing belt was changed about 10k ago. I’ll check the distributor cap for cracks. Thanks for all the help so far i'll let you know how it goes.
    Hackensack, NJ
    Yeah, but will a bad cap and rotor cause it to smoke from the tailpipe?
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by superdesi
    a faulty cap or caked up rotor will cause insufficient spark transfer. This leads to improper conbustion in the cylinders due to weak spark pushing more unburnt gas than normal. All engines run richer than stoich under idling conditions, esp under warm up conditions to bring the engine to normal operating temp. So once the ignition problem is fixed, u will be running how its supposed to be running and burning right amount of fuel.
    LXi User BlueBead's Avatar
    May 2004
    '87 Carbed Hatch(RIP), 88 FI sedan w/ power group, '73 Jag w/ 350lump
    Vancouver Island BC
    What he said; get that combustion going!
    Mar 2004
    Columbus, Ohio
    While checking the cap for cracks, which it appears to not have any, I heard an arcing sound from the cap while it was missing. I checked all plug wires to insure connection and got zapped by one of the wires. After it got my attention I could see spark on the top of the wire where it plugs into the cap. Bad wire?
    Austin, Texas
    yeah, the vibration and rubbing of the wires can wear a thin spot or even get down to the "bone"
    also alot of the time the cracks in the caps are VERY hard to see.
    youre in for a tune up my man, plain and simple
    Car Pics
    vBGarage
    10/Honda/Ridgeline
    NJ
    plugs: $1.50 (ex: Bosch platinums)
    Wires: $30-$40 (Magnacore, NGK, Moroso )
    cap and rotor: $15 - $20 (Bosch, AcDelco)
    These are available in any parts store like ur local national auto parts store, autozone or advance autoparts. U can also check up on Pepboys and Straus if u want.
    NOTE: Whenever u intall the plugs. Clean the plug area BEFORE u pull the old ones out and then apply antizease on the new plug threads and hand tighten it and then use a torque wrench to torque it to 13 ft-lbs. NEVER over tighten it. a regular 21mm or 20mm socket would fit our sparkplugs and u dont have to spend extra money to get the spark plug socket.
    Austin, Texas
    plugs: $150 (ex: Bosch platinums)
    platinums are for high compression engines. they are a wast of money in our engines. i would just go with NGK iridium tips IF IT WERE ME
    i also thin Bosch is overrated anyway, IMO
    Car Pics
    vBGarage
    10/Honda/Ridgeline
    NJ
    platinum is for high compression?? the ones i got have our normal gap and are hotter plugs. U dont use hot plugs for high compression. Iridium on the other hand is about $6 EACH and its a colder plug. Its used for forced inducted motor or high compression motor. now YOU are wasting money buddy.
    BOSCH is good, even tho they have made a name for themselves, they are still one of the best and readiliy available. Its like saying Honda is overrated as compared to Kia or Hyundai when they all pretty much the same reliability ratings. ((but yeah they do look like butt)).
    Austin, Texas
    dude, i used to sell the shit. my opinion has nothing to do with the name they built for themselves, but simple the quality and cost of the parts. bosch was no better than our house brand on reliability and cost 3X the amount. im not bashing on Bosch or there products, im just telling the experience ive had with their products.
    and on the platinum, you go me there i guess. i read and was told that platinum plugs where for vehicles with 10:1+ compression ratio. and i like the iridium because with my experiences with this car and other plugs they turned out the best with long life span, basically cleans itself and never get corroded. but i dont know like i said, just IMO
    Car Pics
    vBGarage
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Who in the hell would pay $150 for spark plugs? I've got NGK Iridium plugs and I paid $26 for them. NGK are OEM plugs too.
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by SteveDX89
    sorry about the typo it should have been $1.50............. smart butt
    Blkblurr's Avatar
    Dayton, Ohio
    If a tune up doesn't work try replacing your oxygen sensors. I paid $25 apiece for mine.
    chicago , il.
    dude if you got zapped and seen spark...that's one of the problems.
    that happened with me.
    this is weird..i had done a coolant change and i had the hose right beside the cap. and i went to start it up, and she was in a warm up mode.
    i went to touched the top hose and it zapped the hell out of me.
    and nuber 4 was sparking like crazy.
    Mar 2004
    Columbus, Ohio
    That was a hell of a zap to and I did it like 4 times. The old plugs and wires are Autolite they worked well this far. I was thinking about another type of plug but I'm really not expecting too much performance out of this old 2.0. I am just looking for an inexpensive plug and wire set to get my by for now. And the list of items and prices looked pretty good to me. I must wait until this Friday before I can do the tune-up so I have some time to research the topic. Could the O2 sensors cause this problem with out a ECU code? I also thought that this problem could have been caused by the main fuel relay that I already fixed once?
    Blkblurr's Avatar
    Dayton, Ohio
    The oxygen sensors can cause a problem if worn or contaminated by silicon and not cause an ecu code. I would try new wires and plugs first.
  1. Christmas came early
    By MessyHonda in forum Performance
    Last Post: 12-25-2007, 05:10 PM
  2. Christmas cam early for me this year
    By Pico in forum Classic Honda Pics & Videos
    Last Post: 12-27-2006, 04:37 PM
  3. Can I integrate an early 90s Bodykit?
    By sk8ordie133@hotmail. in forum Interior & Exterior Care
    Last Post: 02-09-2006, 03:51 PM
  4. early 90 euros on 3gee
    By hondamotorz in forum Interior & Exterior Care
    Last Post: 02-18-2005, 12:19 PM
  5. Umm, some kind of early navigation system in 3G??
    By thegreatdane in forum Classic Honda Community Chat
    Last Post: 08-05-2004, 07:53 PM
