Results 1 to 6 of 6
Thread: this creaky spring will drive me to drink... ...even more than i already do!
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    Unhappy this creaky spring will drive me to drink... ...even more than i already do!
    AHHHHHHHH!!!!!!
    I can't take it anymore. About 2 weeks ago my damn front drivers side spring started to sound like a creaky door that needs about a gallon of grease. I get in: Creak! I get out: creak! I stand on the door sill with the door open (obviously), and bounce to find out where the F*CK that F*CKING creak is coming from, and: CREAK, CREAK, CREAK!!!!!! It's more annoying then Jim Carrey in Cable Guy. All I can figure is that the spring in on it's way, and lucky me, that sound travels nice and loud right into the cabin, and when stopping or going: CRE-f*cking-EAK!!!!!.
    Does this sound like the spring is the culprit?
    -Mark D.
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    It probably is your spring, but mostly I think it's the strut. What happens is that once the strut gets worn out it puts most of the weight on the spring, and then the spring gets worn out and either squeeks, get physically broken (like mine) and then squeeks. Iam pretty sure this is your problem. Just buy some new struts and have new springs put around them and you'll be fine.
    R.I.P. Died on 7/2/03......
    Jul 2002
    Newtown, CT
    hey 88WhiteLX-i --->
    Thanks. Yeah that probably exactly what it is. I know that the struts have been bad for the past 5K+ mi. and already have the Koni Red's to go in there, but have been too lazy to change them out, and as a result I blew up my spring, oh well. Guess that gives me a real reason to go and get those B&G's like I've wanted for ever.
    -Mark D.
    SEi User
    81 HB LX, 84 HB S, 89 LX-i Coupe
    Indianapolis, IN
    I've had bushings replaced, too. I'm not good at suspension stuff, but I had a horrible creak... My Honda friend said these bushings go fairly often, as do coil springs.
    Jul 2002
    Newtown, CT
    I just got brand new control arms with bushings. Yep, those are also waiting to go on. What else is new.
    Anyway, if there are other bushings that I should replace while I have the front end apart, let me know.
    -Mark D.
    accord HB ( metallic green)
    B.C Chilliwack
    probably the lower control arm bushings, prob the outerMine was doin that damnnn anoying, replaced the inner/outer and that solved it .. The one bushing that connects to the fork needed close to 2000lbs in a hyd. press to get it out . so it could be the strut or the bushings hard to tell.
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
  1. Creaky Front Suspension
    By Haxxorz in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-15-2011, 12:06 AM
  2. Lowering spring stiffness % over stock spring stiffness
    By Jims 86LXI HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-22-2005, 10:31 AM
  3. what do you drive?
    By bobsaccord in forum Classic Honda Community Chat
    Last Post: 06-16-2004, 12:03 PM
  4. Spring Tech Coilover spring rates
    By 89AccordLvr in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-01-2003, 10:28 AM
  5. Drink Holder spot
    By Tref_LXI in forum Classic Honda Community Chat
    Last Post: 03-27-2003, 07:13 AM
