Results 1 to 8 of 8
Thread: Question regarding electric fan.
    89 Accord LX-i
    Central Oregon
    Just out of curiousity, does everyone's electric cooling fan turn on when the key is in the "ON" position, and run constantly, regardless if the engine is actually running or not? I know the Radiator in my car was replaced before I bought it, maybe the guy I bought it from just wired it this way?
    "Without high school drop-outs,
    some guys would starve"
    Easy Money
    Quote Originally Posted by pendejo
    Short answer NO
    Only come on when the car gets hot hes got them hot wired for some reason.
    LX User AccordNut's Avatar
    89 LXi 5spd Coupe Sunroof
    Camp Lejeune, NC
    hopefully its just wired wrong and your engine isnt running hot all the time...mine usually only cuts on in the summer time, it does cut on when the engine isnt running thats normal, but not all the time
    HostileJava's Avatar
    Northampton, PA
    Sounds like someone wired them to come on when you start the car instead of when the sensor turns them on. Could be a couple reasons for this, the car could have been overheating, the wiring may have gone bad and it was just rewired, or the sensor may not have been turning the fan on when it should have been.
    89 Accord LX-i
    Central Oregon
    Kinda what I thought. Thanks. Now, where to start to fix the problem?
    Easy Money
    May 2003
    88 Accord LX 88 Accord LXi
    First you should check to see if the fan sensor is even hooked up. Look on the bottom of the radiator for the sensor. See if the connector is on. If it's not you will need to locate it and see if someone jumped it out. Being that it runs all the time, the chances are good that the sensor is bad and was jumpered out as a quick fix. You might get lucky and all you may have to do is change the sensor and connect it back up.
    89 Accord LX-i
    Central Oregon
    Gracias
    Easy Money
    May 2003
    De nada. Let us know what you find.
  1. Electric INTAKE !!!!
    By SladeHonda in forum Performance
    Last Post: 04-16-2012, 09:24 PM
  2. electric fan ?
    By ripcord in forum Carburetor Tech
    Last Post: 04-18-2011, 01:10 PM
  3. Electric issues
    By -$MOKIN- in forum 3geez Accords
    Last Post: 08-25-2008, 12:59 PM
  4. Electric power 3g
    By carotman in forum Classic Honda Community Chat
    Last Post: 02-17-2003, 02:18 PM
  5. electric supercharger?
    By LX-i dragon in forum Performance
    Last Post: 07-20-2002, 03:41 PM
