Didn't see any thread that addressed this directly so I will give you the lowdown. I'm sure most of us know how this is done but for others it isn't obvious how this adjustment is made.
On the intake manifold, you will notice the idle air control valve, the thing that gives you surging idle problems when it goes bad. It will have two screws on the top. (Now I would suggest adjusting this with the engine off) Unscrew them, remove the top and there will be a large adjusting screw inside. You'll need a wide screwdriver or a knife to adjust it. It isn't hard to adjust so you dont need something that will take a lot of force.
Anyway, turn it clockwise to lower your fast idle, counterclockwise to raise it. Put the cover back on, screw it back down and test. This also solves some problems with your idle going way way up there.
Hope this helps.![]()
