PART ONE: CHOOSING YOUR INDUCTION METHOD
CARBURETED
1. When well tuned can offer good throttle response.
2. Uses simple tools to maintain and tune.
3. Offers intake air cooling from fuel vaporization
4. Suffers from fuel delivery problems when cold.
5. Suffers from fuel slosh, hard cornering, or steep inclines.
6. Intake manifolds need to be designed to flow fuel
7. Suffers from venturi and booster venturi air restrictions
8. Not self adaptable to big changes in altitude, or large increaese decreases in engine demand.
THROTTLE BODY INJECTION (TBI)
1. Gets rid of any problems the float bowl may cause
2. Gives the user more tunability options then carb
3. Suffers in that it need to flow fuel in the intake manifold, ususally requires carb manifold.
4. The injectors may restrict air flow into the barrels.
FUEL INJECTED
1. For performance fuel economy and lower emissions Fuel Injection is the way to go.
2. Fuel injection does not have to design their intake manifold to flow fuel.
3. Fuel injection does not have to worry about fuel slosh, steep inclines, or hard cornering.
4. Less air restriction then CARB or TBI
INTAKES
- STOCK AIR BOX MODIFICATION
1. The step up from a cold air factory induction air box to a aftermarket induction system may not be as benificial as you might think.
2. The stock air box after the filter may have areas that create turbulent airflow.
a. Reducing turbulent airflow into the intake pipe will be a good improvement, you can intergrate or buy aftermarket stock airboxes that use funnels/air horns after the filter to help reduce tubulence.
3. The stock air box usually has one main restriction prior to the filter inside the box. This restriction is the pipe which draws in cold air from outside the engine bay. For Carburetors most people will flip the lid to get around the restriction, I haven't seen anyone remove the filter lid on an EFI to give the filter full access to the air.
a. Replacing the stock filter can be a good improvement.
b. Removing the restriction prior to the filter and improving air flow to the stock filter can be a good improvement.
c. Reducing hot engine air from reaching the filter by using heat barriers and ducting of cold air to the filter can be a good improvement.
- DEI HEAT SHEILD SHEETS (LINK)
1. Single layer protection, good to shroud off area near battery to keep out hot engine air.
- DEI DUAL LAYER HEAT SHEILD SHEETS (LINK)
1. Dual layer protection for direct surface contact.
- AFTERMARKET INTAKE
1. If aftermarket intake is better suited for your situation take the time to make sure you really are improving air flow.
a. Installing a large intake filter will make sure you don't choke the motor.
b. Inside the large filter you can install a funnel to reduce air flow turbulence.
c. Properly placing the filter and sheiding the pipe from heat sources will unsure you get the most cold air possible.
d. Try to limit the number of bends in the intake pipe, also limit how long the pipes are, use only what you need to get the filter to the cold air source.
2. Pre-Plenum Plenumed Intake pipes or Resonant Intake pipes may have an advantage you might want to look into.
- AEM V2 INTAKE (LINK)
