Results 1 to 6 of 6
Thread: Exhaust problem? ( Auto Trans Problem )
    89 4dr Lxi,91 Accord EX, '93 Fleetwood, 66 Impala SS, 64 Impala, (63 Impala 4 sale)
    Bremerton,WA
    Question Exhaust problem? ( Auto Trans Problem )
    I just reinstalled my Pacesetter header today, but this time I added a "highflow cat" and got rid of the air suction tube, or whatever you call it that comes out the side of the header and connects near the egr. Well it would stumble in the lower rpm's and would shift to early. So I switched the o2 sensor connectors. That seemed to keep it from stumbling, but it still seems to shift to early. Before if you would step on it it would go into the higher rpm's with no problems. Now it seems to shift slowly at around 4,000-4,500. Could installing the high flow cat have caused this? If anyone has had this same problem please reply, cause if not im tearing this shit apart tomorrow and throwing the stock cat back on!
    shepherd79's Avatar
    Falling Waters, WV USA
    i never heard to high flow cat causing this kind of problem.
    the shifting problem is related to loose TV cable. adjust it according to manual or just play with it.
    the ruff idle could be anything. did you reset ECU after you swaped the O2 plugs?
    LX User snow_man_20's Avatar
    89' Accord LXI
    oregon
    i'm sorry i don't know much about automatics, but does the pacesetter header have both o2 sensor inputs? could the o2 sensers gotten damaged during the swap??
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Here is a thread that should help answer your questions
    https://www.3geez.com/showthread.php?t=40885
    There is an animated image showing proper TV cable adjustment
    Bremerton,WA
    Maybe my wording wasn't the best, but it's almost more like it bogs down before it shifts, compared to "it shifts to early". I didn't have this problem before so I thought maybe it was something I added. Thanks A20A1 I checked out the link you posted and everything seemed fine on my tranny. Could the bogging down be a cause of the 2.25 piping to the stock cat flange (which is less than 2inches)and then to the 2.5 cat? Could that cause like a restriction in exhaust flow since it's not the same diameter when it flows into the exhaust piping? I didn't realize the diameters til i looked on the box.The o2 sensors are fairly new,should I also replace those? Sorry for all the questions, but I never had a problems like this before.
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    what did you do with the egr pipe, did you cover the holeż If the the car is sucking in air from the egr valve, that could be why you are bogging down.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
  1. 88 carbed auto trans problem
    By stangrcr1 in forum 3geez Accords
    Last Post: 04-22-2010, 04:19 PM
  2. B20A auto trans problem
    By 2oodoor in forum JDM B18A / B20A Swap Tech
    Last Post: 07-07-2009, 03:19 AM
  3. 88 auto trans problem
    By Chodaboy69 in forum 3geez Accords
    Last Post: 03-02-2006, 06:55 AM
  4. trans problem
    By THE_LoserNextDoor in forum 3geez Accords
    Last Post: 09-04-2003, 06:16 AM
  5. weird trans problem
    Last Post: 01-13-2003, 05:41 PM
