Results 1 to 5 of 5
Thread: My CD Player
    LX User phoenxislayer15's Avatar
    1987 Honda Accord Hatch
    Greeneville, TN
    My CD Player
    Ok, so I deiced to go outside and hook up my CD player today...and of course something had to go wrong. I had it all hooked up and working, and then it would not turn on. The CD players pwr light is lit up red, but it will only eject and accept CDs, then turn off. I replaced the fuses going to the CD player power wires, and I'm sure the radio fuse is good. CD player is also still good... Any ideas?
    LX User snow_man_20's Avatar
    89' Accord LXI
    oregon
    i would have to say your cd player is bad, if you have the ground (black), memory (yellow), and power (red) all with good conections you should get power and the clock should stay ontime. If there is no power at all check your fuses under your dash, the fuse on the memory wire should never blow because your indash fuse should blow before your memory fuse. Also if you used your harness from the old stereo and used a harness from wallmart or stereo store and got good conections on all of the wires it should work good. good luck
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    yeah, even if you hook up the power and memory wires backwards it will still work while the car is on, you just lose your settings whne you turn it off. so i'd say its a bad radio. test it in another car tho if you can.
    DX User Accord_Beater's Avatar
    1988 Honda Accord LX & 1998 Chevrolet Blazer Zr2
    Winnipeg, Manitoba, Canada
    Easiest way to check, is hooking up the Yellow and Red wires directly to the positive terminal of your battery, and the Black wire to the Negative terminal of your battery.
    This will tell you if there's just a wiring problem, or if it really is the deck.
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    Agreed, before I install a cd player or anything that is electrical, I always test it before it gets put in to look nice n pretty. Nothing is worse than having it completely installed only to find out it doesn't work right or work at all.
  1. my 4th gen tape player & cd player
    By A18A in forum Interior & Exterior Care
    Last Post: 10-28-2006, 06:25 PM
  2. Factory CD Player/Cassette player
    By Alexi3rdgen in forum 3geez Accords
    Last Post: 09-10-2006, 12:06 PM
  3. I cant get my cassette player out to install my cd player! HELP
    By 87lxaccord in forum Interior & Exterior Care
    Last Post: 11-23-2003, 07:14 AM
  4. CD player.
    By MarioBurke in forum Trading Post
    Last Post: 11-20-2003, 07:36 PM
  5. Need a used cd player....
    By goldyaccord in forum Interior & Exterior Care
    Last Post: 10-17-2002, 05:29 PM
