Results 1 to 6 of 6
Thread: Has this been documented or is it not possible?
    1989 Mitsubishi Mirage Turbo
    California
    :pimp: Has the B20 prelude swap been done or documented online ?I here its possilbe but its a pain.I have ALOT of prelude stuff minus the hydro clutch setup but will it work?
    carotman's Avatar
    Montreal South Shore
    too much trouble I think.
    You need to do your OWN engine mounts and wiring.
    The B20A is not a bolt on swap
    I need these parts!
    S.Glastonbury, CT
    Prelude B20
    well awhile back there was a post from someone at placeracing. They did all of the swap and they ran into trouble converting it to a hydralic clutch because the prelude uses hydralic not cable and they never finished it. They did have to cut the frame or chassis to fit it in too. I would say that if they stopped the swap then it was definately a pain to finish so i dont think it would be wise.
    California
    Damn,Damn,Damn,Let's see here.for what I got in this swap I could have gotta B16 at least.I heard it was a pain but damn ,Its sad to say I goofed but I'm going to give place racing a call I'd hafe to here it from them hat this aint going to work
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    The CR-Vtec cultists seem to think the Prelude Si was the worst engine Honda ever created. Something mathematical they did to find some ratio that takes into account horsepower per bore or stroke length or some other such horseshit... Plus valve float. It would definitely be expensive to fabricate everything you would need for it and in the end it's not that great an engine anyway. I'll post a link to the article where I read about the ratio thing they did (if I can find the thing), I forget where it was.
    ~<+045+ygH05+>~
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    OK, ummm, let me read your reply right...you ALREADY started the conversion to a Prelude B20???
