Results 1 to 16 of 16
Thread: Royal Screwage
    LX User phoenxislayer15's Avatar
    1987 Honda Accord Hatch
    Greeneville, TN
    Royal Screwage
    Well it's about 15 degrees outside, and I guess it was a bad idea to degrease my engine now. However, I did it then washed it off. When I went to drive it though, it sounded like it had blown a plug or something. I have no clue what's wrong with it and I am very pissed...
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    well a little more info on what exactly is going on would be helpful. Is it running rough? sound funny? is it puttering like the plug was blown out of the head or just not firing?? I'd check your distributor cap and see if you got any water in it or anything.
    Hope it works out for ya.
    Nothin' 2 Old Racing
    Greeneville, TN
    I'm thinking water got somewhere, because it does sound like a plug is not firing. Sounds like a chopper really, putter putter putter no power. Usually a plug problem. I will have to check them tomorrow after I grab a ride to school, and it being so fucking cold does not help.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    yeah, sounds like you might need to let some things dry out, namely your distributor cap. When you pull it off, make sure its in good working condition and nothing was fried.
    Greeneville, TN
    Think if it has time to dry it will be good? BTW get on AIM if you can...
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    if its parked somewhere warm it probably will try out, but not if its outside in the 15 degree weather.
    Greeneville, TN
    I have nowhere warm to park it, any ideas?
    DX User SavageG's Avatar
    Jul 2004
    86' Accord Lxi, 79' TR7, 73' VW bus, 03' WRX
    Portland, OR
    How long did you run it? I had a sentra that did the same thing and the only way to get it dry was to idle @ 2000rpm for 5min or so. Also you might check to see if you have any uncapped vacuum lines?
    Like NXRacer said, nothings going to dry out if it's 15 degrees out, the water will just freeze
    Greeneville, TN
    NX rules, turns out it was the distrib cap. Took it off took a blow dryer to it, slapped it on ran like crap on wheels,(normally how it runs is crap on wheels). Thanks man.
    SEi User myaccord7's Avatar
    89 honda accord LX
    Quincy,IL
    i hate cold weather
    LXi User BlueBead's Avatar
    May 2004
    '87 Carbed Hatch(RIP), 88 FI sedan w/ power group, '73 Jag w/ 350lump
    Vancouver Island BC
    I hear you on the f-ing cold weather! I've got rain on top of a foot and a half of snow, so now its puddles on 4inches of ice/slush...
    I've been thinking about degreasing too.... I guess now'll I'll wait till it warms up alot more
    The problem with the gene pool is that there is no lifeguard;
    And the stupid people are breeding......
    http://www.cardomain.com/id/bluebead
    Greeneville, TN
    Degreaser did absolutely nothing on my engine...
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    the best thing i've found so far for cleaning engines is Simple Green. You can pick it up at pretty much any store. Works WONDERS on dirty engines.
    May 2004
    Vancouver Island BC
    NX how do you apply it? I've seen the spray bottles but I'm assuming you used a brush or something to work it into the heavy deposits... and do you cover the electrical components? I want to do this with a minimum of f*ck-ups
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    for the most part, you just spray the shit out of your engine bay and let it soak, then hit it was a power washer. I've done it before and only covered the intake filter and everything was fine. If you have the time, it wouldnt be a bad idea to cover up the alternator and and distributor just to be safe.
    If you dont have access to a power washer, a self service car was will do the trick. Obviously this isnt something to do when its cold out.
    Greeneville, TN
    Some kind of joke?
    Anyway yeah, wait till it warms up which is what I'm going to do. Cover Distrib, Intake, and Windshield Wiper moter, giving me problem now...
  1. Royal purple oil??
    By Mantis88LX in forum Performance
    Last Post: 10-02-2002, 03:38 PM
  2. How Much Oil? Royal Purple?
    By kevins89lxi in forum 3geez Accords
    Last Post: 05-04-2002, 12:23 PM
