i was just wondering can anyone tell me if it is ok to use kyb gr-2 gas shocks with ground control coilovers....anyone....please
Mine Looks Better Then Yours!!!
Absolutely, NO, do not do that. KYB GR-2's are nothing more than oem replacement struts. Even KYB doesn't call them performance struts. All lowering coilovers and springs are stiffer, you have to run struts that are likewise stiffer. Even Tokico's H.P. struts and Bilstein H.D.'s (unless revalved ) don't have that it takes either. The only strut you should run with ground-controls are koni special's. And even the koni's are barely stiff enough for them. Revalved Bilstein H.D.'s would be a better choice.
I know ground-controls are expensive, but you don't want to screw up your car with weak sturts that will never let you experience what those ground-controls are all about. One of our members found this out the hard way when he tried to run tokicos with his ground-controls, he now running Koni's in the front and the tokico's in the rear.
Now I d
thanks alot man, i soo soo soo glad i asked before i did that. because i have them sitting in a bow next to me... ...another question...if i wanted to lower my car 3 inches max...what all would need to be done to keep the camber in line...thanks alot again
in a box*** next to me
Well I'm glad you asked, it would really ride like sh**. As you've figured out, you'll need some kind of camber correction in the front. At a 3" drop I'm pretty sure you'll need camber correction in the rear as well. For the front you can purchase camber kits form eibach and ingalls. Or you can go so a junk yard and pick up a pair of control arms off of a 2nd gen prelude and get some washers to make them fit. Check out some of the post's on prelude arms and you should be able to get an idea of how to install them. For the rear ingalls does make a rear camber correction kit.
Can you return the GR-2's? I sure hope you can.
Now I d
yeah i should be able to...if not ill sell them and pick up some koni specials
thanks for all your help
No problem, thats what I do
Now I d
are the koni specials the adjustable ones?
89 Silverstone Metallic LXi, custom Air Intake, DC Sports 4-2-1 header, A'PEXi N1 exhaust with 2.25" pipe, ACT clutch, Xenon body kit
3geez member since July 11, 2001
[i]
One of our members found this out the hard way when he tried to run tokicos with his ground-controls, he now running Koni's in the front and the tokico's in the rear. [/B]
Hehe :::looks around:::
'88 LX-i Coupe --- LS/Vtec
Yes they are single adjustable for rebound, but not for compression. If they could be adjusted for compression you'd be able to make them stiffer or softer. The rebound adjustability is what lets you dial out bounce,....thank godOriginally posted by GDGuy11B
Now I d
